Re: Generic x86-64 6.6 boot image boots but doesn't respond to USB keyboard
10/01/2018 5:06 AM
post119171
Hi John,
the compiler error you see may be related to some mismatch between audio patches installed/not installed in your SDP 6.6
installation and the sources in the BSP you are using. Which x86 BSP are you using? Did you install the corresponding
*_PATCHES.zip archive as outlined in the documentation?
To workaround this, I think it is not necessary to build the sources. You can just issue "make images", the build would
then use the prebuilt binaries, which get copied from "prebuilt" folder to "install" folder automatically.
You could try to work with startup-bios to see if that changes anything. This is what QNX 6.5 is doing by default.
Al
03/01/2019 12:17 AM
post119552
Hi Folks:
We have been working with QNX 6.5.0 but would like to transition to 7.0.0. The prebuilt image starts up OK, but when I
build the binary from the x-86_64-generic.build file that was sent with the BSP, I still cannot use the keyboard, nor
are PCI devices being seen by their drivers.
The CPU we're using is the Intel 3845, mounted on RTD's CML24BT PCI/104-Express cpuModule. The pci_device.list does
see both the SATA disk and ethernet interface, but the corresponding daemons (devb-ahci and io-pkt-v6-hc, respectively)
cannot see them.
By the way, we're using the BSP_x86_64_br-700_be-700_JBN89 board support package.
Any ideas?
Best regards,
John
