devc-ser8250 driver no longer in true raw mode when moving from QNX 6.3.2 to QNX 6.5.0
11/10/2017 6:16 PM
post118191
I am seeing a problem with the devc-ser8250 driver since we have upgraded from QNX 6.3.2 to 6.5.0. Regardless of the
terminal settings (default we use are iflag:2010 oflag:4 cflag:FB0 lflag:0 but I have tried many combinations) I am NOT
getting a true raw mode on reads. The specific problem is that the first byte immediately following any byte with the
least significant nibble as an F is missed. This happens at the read() level and is immediately resolved by downgrading
back to QNX 6.3.2 from 6.5.0.
The command to devc-ser8250 is “devc-ser8250 -b57600 -F -u3 208,10 1208,10 2208,10 3208,10 3200,10 2200,10 1200,10 200,
10” though here again I have tried many combinations.
We are running QNX on a VSX-6124 System on Chip card running a Vortex86SX CPU. The SOC is installed in our custom
motherboard on an ISA bus and the DUARTs used on the serial ports on that motherboard are pc16552DV chips.
I have been working on this for some time and would very much appreciate any advice or suggestions.
Blaine Hatch
