How to build QNX RTOS Cross-compiler using Scons build environment ?
01/19/2015 11:35 AM
post112997
Hello experts...
I am QNX development beginner.
I would like to develop a AllJoyn application that runs on the QNX RTOS using AllJoyn Framework.
[[Reference------------------------------------------------------------------------------------
* AllJoyn™ is a collaborative open-source software framework that makes it easy for devices and apps to discover and
communicate with each other.]
* AllSeen Alliance(https://allseenalliance.org/)
* AllJoyn Framework is open source. And AllJoyn’s build tools are “Python” and “Scons”.
* Scons tool builds “AllJoyn open-source-code” using “gcc”. Then,AllJoyn library is created.
I don’t know about the QNX RTOS build environment and Scons build environment.
So I'd like to know about the QNX RTOS application development using Scons build environment.
Please answer a few questions.
How to build QNX RTOS Cross-compiler using Scons build environment ??
Is it possible to build using "Scons tool" ?
Can I use an AllJoyn library(The library was built with Scons build "gcc") on QNX RTOS ..?
If can not use the library using gcc, how can I change the “Scons build tool” ?
Can QNX Cross-Compiler support the “Scons build tool” ?
If QNX compiler can support, how can I make the QNX cross-compile environment in “Scons build tool” ?
Thank you.
