USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 12:07 PM
post111225
I would like to use the USB Device as a USB to Ethernet port, so I can debug the board with usb instead of the RJ45
ethernet port. So far I was able to get the USB Device Mass Storage working and tried to replicate the steps for the
USB Device Ethernet (NCM), but I noticed there are differences; such as, the following:
1. In rules.lua when creating the Device_Stack = {
cmd = 'io-usb-dcd -dusbncm-mx6sabrelite-ci ioport=0x02184000, irq=75';
path = '/dev/io-usb-dcd/io-usb';
descriptors = {usbncm, usbser, umass};
An error of
# Must specify irq with ioport optionIn function usbdc_attach_hub -- /builds/660_SDP/svn/hardware/support/publishers/
usblauncher/dcd.c:247 device_root_hub != NULL -- assertion failed
2. In rules.lua there is no specific driver to invoke when creating device(), so instead tried using the following
commands
start"mount -Tio-pkt -o mac=123456789abc, protocol=ncm devnp-usbdnet.so";
OR
driver"io-pkt-v4-hc -d usbdnet protocol=ncm, path=/dev/io-usb-dcd/io-usb, mac=123456789ab";
3. However, if I used the mass storage Device Stack of
cmd = 'io-usb-dcd -dusbumass-mx6sabrelite-ci ioport=0x02184000,irq=75'
and use the command for device()
The program can run, but when looking in the Windows 7 Device Manager, I am seeing the device under "Other" instead of "
Ports" or "Universal Serial Bus Controllers"
Please let me know if I am missing anything.
Thanks.
Re: USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 1:03 PM
post111228
I see a typo in the command-line. Try removing the space before 'irq'
-cmd = 'io-usb-dcd -dusbncm-mx6sabrelite-ci ioport=0x02184000, irq=75';
+cmd = 'io-usb-dcd -dusbncm-mx6sabrelite-ci ioport=0x02184000,irq=75';
Could you provide your complete Lua file and how you a starting io-usb (the PPS command used), and how io-pkt is started
, if using the mount command to mount in the devnp-usbdnet?
07/25/2014 1:06 PM
post111229
These extra spaces following a comma are probably causing you trouble. Options that are comma-separated should not have
any spaces.
start"mount -Tio-pkt -o mac=123456789abc,protocol=ncm devnp-usbdnet.so";
driver"io-pkt-v4-hc -d usbdnet protocol=ncm,path=/dev/io-usb-dcd/io-usb,mac=123456789ab";
If you use the mount approach, remember to use the path=/dev/io-usb-dcd there too.
07/25/2014 1:29 PM
post111230
You are right about the spacing. So the Device_Stack can now recognize the -dusbncm. Please find the attachment to be
the *.lua files i am currently using. As for starting the the io-pkt, I am assuming in rules.lua for configuring a
device(), the execution/start will be from
I also did confirm the correct device is being performed by commanding
echo "start_stack::device,1">>/pps/qnx/device/usb_ctrl
And when looking in the Windows 7 Device Manager, I do see the proper VID and PID for the specific device.
RE: USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 3:07 PM
post111232
If you start usblauncher with -vvvv -l
after running
what do you see in sloginfo?
what's the output of nicinfo?
How many io-pkts are running (please provide pidin arg output after the start_stack::device,1 command completes.
From: Christopher Olarti [mailto:community-noreply@qnx.com]
Sent: Friday, July 25, 2014 1:29 PM
To: osmeta-core_os
Subject: Re: USB Device Ethernet to replace the RJ45 Ethernet
OSMeta
http://community.qnx.com/sf/go/post111230
To cancel your subscription to this discussion, please e-mail osmeta-core_os-unsubscribe@community.qnx.com
Re: RE: USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 4:17 PM
post111233
Please find the attachment for the data you are asking for.
RE: RE: USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 4:21 PM
post111234
Thanks. I see that you already have an io-pkt running, so I think you should use the mount -Tio-pkt method instead of
trying to start a second io-pkt.
Then, run nicinfo after starting the device stack, see if ncm0 shows up.
Sent: Friday, July 25, 2014 4:17 PM
To: osmeta-core_os
Subject: Re: RE: USB Device Ethernet to replace the RJ45 Ethernet
OSMeta
http://community.qnx.com/sf/go/post111233
Re: RE: RE: USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 4:52 PM
post111235
It looks llike something is happening. When I removed the device() call and just started ncm device stack
the windows machine started trying to install the drivers, but failed.
When trying to mount on the command window instead of using rules.lua
# mount -Tio-pkt -o mac=123456789abc,protocol=ncm devnp-usbnet.so
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such device or address
then when using nicinfo i do not see ncm0
RE: RE: RE: USB Device Ethernet to replace the RJ45 Ethernet
07/25/2014 5:04 PM
post111236
Ok, at this point it's probably best to create a support ticket and allow us to help you through this portal.
Please remember to include all command output in chronological order.
I find it can help to start sloginfo -wt &
so that it's running in the background, -t gives ms precision instead of just seconds, -w waits and prints new logs as they are generated, and then we can follow your steps more easily.
Sent: Friday, July 25, 2014 4:52 PM
To: osmeta-core_os
Subject: Re: RE: RE: USB Device Ethernet to replace the RJ45 Ethernet
OSMeta
http://community.qnx.com/sf/go/post111235
