Forum Topic - USB Device - usblauncher unable to update from *.lua files:
I am trying to make my target board, SabreLite, to be a USB Device; so when I connect the SabreLite to a PC, I want to
at least see the VID and PID in the PC Device Manager.  I understand the PC side will need an *.INF file, but the VID
and PID that are hexadecimal should still be updated.
So far i have tried updating the IFS boot script to include the PPS, to launch the usblauncher, and created the
necessary directories for the *.lua files.  However, when executing the boot script, the PPS is missing a /var/pps.  The
 usblauncher is able to run, but when performing usb -vvv I do not see the VID and PID updated to my *.lua files.
When trying to create the missing directory with mkdir, i get an error: Function not implemented.
I also tried a QNX recommendation to run usblauncher through the SD mount.  I am able to get the usblauncher to perform,
 but when using usb -vvv I am still seeing the USB controller being a Hub, when I want it to be a device with the
information from the *.lua files.  Also I am still unable to create a directory, when using mkdir.
So I would like to know if i need to mount a different binary for creating directories (mkdir)?  Also is the PPS really
necessary to execute the usblauncher, so it can update the usb controller with the necessary *.lua files?
Thanks in advance.
RE: USB Device - usblauncher unable to update from *.lua files
After starting usblauncher, would you be able to post the output of "pidin arg", at least the portion that shows io-usb
or io-usb-dcd and usblauncher running?
Would you be able to post the "Host_Stack" and "Device_Stack" portions of your Lua file that usblauncher is reading in?
If you run
echo "start_stack::device,1"  >> /pps/qnx/usb_ctrl
what happens?  check "pidin arg" again and see if io-usb-dcd has started.
Is the USB device that you're making serial-USB, umass, or something else?
I think we can ignore the missing /var/pps for now. It's not needed for what you're trying to accomplish.
From: Christopher Olarti [mailto:community-noreply@qnx.com]
Sent: Tuesday, June 17, 2014 5:44 PM
To: osmeta-core_os
Subject: USB Device - usblauncher unable to update from *.lua files
Thanks in advance.
OSMeta
http://community.qnx.com/sf/go/post110732
To cancel your subscription to this discussion, please e-mail osmeta-core_os-unsubscribe@community.qnx.com
Re: RE: USB Device - usblauncher unable to update from *.lua files
Thanks for helping with my current situation.
Please find the attachment to be the data you are requesting.
I have been switching from serial and mass storage, but the data log is for the serial communication.
Thanks Again.
Attachment: Text usblauncher_data.txt 4.85 KB
Apologies also find the following attachments to be the rules.lua
Attachment: Text rules.lua 8.56 KB
RE: RE: USB Device - usblauncher unable to update from *.lua files
I think two key things to watch for is to not start io-usb-dcd before usblauncher; let usblauncher start the USB stack
for you, and to use the 'echo' command to send a PPS command to usblauncher to start the stack. Also, let usblauncher
start devc-serusb_dcd, instead of starting this from your boot script. usblauncher will launch this driver.
In rules.lua:
lines 79, 96, and 100 need to have the same path, e.g. /dev/otg/io-usb-dcd so that the drivers (e.g. devc-serusb_dcd)
can connect to the USB stack.
to test umass you'll need to uncomment lines 98-101.
I see that io-usb-dcd is running before usblauncher. You'll need to let usblauncher start io-usb-dcd; disable io-usb-dcd
 from your boot script, start usblauncher as you are doing currently, then use the 'echo' command to write the command
text to usblauncher's PPS control object:
# "start_stack::device,1" >> /pps/qnx/usb_ctrl
ksh: start_stack::device,1: cannot execute - No such file or directory
--> this should be:
This command instructs usblauncher to spawn io-usb-dcd, a child process, and establish a connection to this stack. Then
it can override whatever descriptors are in the devu-usbser-mx6sabrelite-ci.so, to take on the personality of 'umass'
or 'usb-serial' (with your VID/DID and any other modifications), launch the appropriate supporting driver (devu-
umass_client-block or devc-serusb_dcd), then enable the USB link so that the USB host (Windows PC) detects the device
insertion.
--> start io-usb-dcd and override the descriptors to be umass, based on the 'umass' Lua table defined in /etc/
usblauncher/umass.lua
echo "start_stack::none" >> /pps/qnx/usb_ctrl
--> usblauncher will slay io-usb-dcd (the one that it spawned in the above step)
echo "start_stack::device,2" >> /pps/qnx/usb_ctrl
--> start io-usb-dcd and override the descriptors to be usb-serial, based on the 'usbser' Lua table defined in /etc/
usblauncher/usbser.lua
I see that you are running io-usb for the host-only port on the sabrelite. What you could do, once the above is working
correctly, is plug a micro-USB cable into the OTG port, and the type A plug end of the cable into the port on the
adjacent side of the board, then type 'usb' at the console and see if your device is enumerated. Or you could use a
diagnostics tool on your Windows PC to see what is detected.
Sent: Wednesday, June 18, 2014 6:52 PM
To: osmeta-core_os
Subject: Re: RE: USB Device - usblauncher unable to update from *.lua files
Thanks Again.
OSMeta
http://community.qnx.com/sf/go/post110755
Re: RE: RE: USB Device - usblauncher unable to update from *.lua files
Hi Andy,
Please find the attachment to be the latest actions for running usblauncher.  I included the *.build file and the log
file.
I commented out the initialization of the USB OTG Mass at the .script portion and made the console.sh run usblauncher -h
.  I did update the *.lua files to be recognized in dev/io-usb-dcd instead of dev/otg/io-usb-dcd.  I also included in
the console.sh the echo "start_stack::device,2" for umass after executing usblauncher.
I noticed in the log file, with "pidin arg", I did not see the device driver for a umass.
Attachment: Compressed file usblauncher.zip 8.26 KB
RE: RE: RE: USB Device - usblauncher unable to update from *.lua files
Hi Christopher,
Could you add -vvvl to the usblauncher command-line, then run sloginfo -t and provide the output?
This turns up the verbosity setting so that we can see what usblauncher's doing at each step. The -l sends the output to
 slogger.
Until you get everything working correctly, I recommend running
manually, instead of in the boot script.
You can run sloginfo in the background, and observe any new output as a response to the commands you enter on the
console:
sloginfo -wt &
then
What output do you see?
It's ok to leave the first io-usb running. You'll need this to use the non-OTG port.  devb-umass appears to fail with "
xpt_configure: umass SIM attach failure" since the first io-usb instance is not running now.
If you have the first io-usb instance running (started by the boot script), then let usblauncher start the io-usb-dcd
for the other controller, you'll be able to connect a USB cable between the two ports and run 'usb' or 'devb-umass' to
test out the client device all on one target.
-Andy
Sent: Thursday, June 19, 2014 1:00 PM
To: osmeta-core_os
Subject: Re: RE: RE: USB Device - usblauncher unable to update from *.lua files
Hi Andy,
file.
OSMeta
http://community.qnx.com/sf/go/post110765
Re: RE: RE: RE: USB Device - usblauncher unable to update from *.lua files
Please find the attachment to be the latest request for running usblauncher with -vvvl.
I am not seeing anything new on the PC Device Manager, so I will be getting a USB analyzer this afternoon and inspect
the bus.
I would like to understand some of the actions better when trying to make the SabreLite a USB Device as a Network,
Serial, and Mass Storage.
1. Under rules.lua, can I create multiple instances of the Device Stack for each USB type?  Under the same Device_Stack{
 } can I have mutliple cmd assignments; for instance:
Device_Stack = {
	cmd  = 'io-usb-dcd -d -dusbncm-mx6sabrelite-ci ioport=0x02184000,irq=75';
        cmd = 'io-usb-dcd -d -dusbser-mx6sabrelite-ci ioport=0x02184000,irq=75';
        cmd = 'io-usb-dcd -d -dusbmass-mx6sabrelite-ci ioport=0x02184000,irq=75';
	path = '/dev/io-usb-dcd';
        descriptors = {umass, usbser,usbncm};
2.  What are the Serial and Networking Interfaces like the following for Mass Storage?
 ## Driver for USB Mass Storage interface
   echo Launching devb-umass...
   devb-umass cam pnp &
   echo done
Thanks again.
Attachment: Text usblauncher_vvvl.txt 18.64 KB
RE: RE: RE: RE: USB Device - usblauncher unable to update from *.lua files
This is like
x = 3
x = 4
x = 5
the final value of x is 5; only the last cmd assignment is used.
The idea is that you use only one command, any of them is doesn't much matter, such as cmd = 'io-usb-dcd -d -dusbmass-
mx6sabrelite-ci ioport=0x02184000,irq=75', then
echo "start_stack::device,1"   >> /pps/qnx/usb_ctrl  # to select the 1st item in descriptors {}, umass USB descriptors
or;
echo "start_stack::device,2"  >> /pps/qnx/usb_ctrl   # to select the 2nd item in descriptors {}, usbser USB descriptors
or;
echo "start_stack::device,3"  >> /pps/qnx/usb_ctrl   # to select the 3rd item in descriptors {}, usbncm USB descriptors
If usblauncher is used to override/set the USB descriptors, then any of the devu*-mx6sabrelite-ci.so shared objects can
be used, since the USB descriptors that are compiled into these libraries are overridden based on how you instruct
usblauncher to start the io-usb-dcd stack.
Were you able to type
at the prompt?
In the last log, I see higher verbosity logs but I don't see that this command was run yet. This command is required to
properly set up the Sabrelite as a USB Device on the OTG port.
Let's try to get descriptor overrides working for mass storage, then we can discuss USB-Serial and NCM after.
Cheers,
Andy
Sent: Thursday, June 19, 2014 2:31 PM
To: osmeta-core_os
Subject: Re: RE: RE: RE: USB Device - usblauncher unable to update from *.lua files
the bus.
Device_Stack = {
   echo done
Thanks again.
OSMeta
http://community.qnx.com/sf/go/post110767
Re: USB Device - usblauncher unable to update from *.lua files
Hi Andy,
Please find the attachment to be the data you requested for usblauncher when the USB Host has been initialized and
letting the usblauncher to perform the USB Device.
Also in my console.sh I let the script to run
## usblauncher
	echo Starting USBlauncher
	usblauncher -h -vvvl -p 2 -t -s /lib/dll/pubs/
then at my command prompt i performed the following commands:
#sloginfo -t
#sloginfo -wt &
#echo "start_stack::device,2" >> /pps/qnx/usb_ctrl
#        <-- No new data was outputted
#pidin arg
usblauncher_sloginfo_t.txt -->just executes sloginfo -t after usblauncher
usblauncher_echo.txt --> appends with usblauncher_sloginfo_t.txt and uses the commands
sloginfo -wt &
pidin arg
Attachment: Compressed file usblauncher_slog.zip 9.58 KB
Hi Christopher,
After the echo "start_stack::device,2" >> /pps/qnx/usb_ctrl
What's the output of
cat /pps/qnx/device/usb_ctrl
mount
Try (manually, at the console):
slay devb-ram
slay pps
slay usblauncher
pps -m /pps/qnx
What happens?
-Andy
Sent: Thursday, June 19, 2014 4:35 PM
To: osmeta-core_os
Subject: Re: USB Device - usblauncher unable to update from *.lua files
Hi Andy,
## usblauncher
#sloginfo -t
#sloginfo -wt &
#pidin arg
sloginfo -wt &
pidin arg
OSMeta
http://community.qnx.com/sf/go/post110770
Hi Andy,
Please find the attachment to be the results from your request.
Attachment: Text usblauncher_slay.txt 1.5 KB
Hi Christopher,
I believe in your build file usblauncher was included in the IFS and the full path is /bin/usblauncher? If so, please
try
/bin/usblauncher -h -vvvl -p 2 -t -s /lib/dll/pubs
This will need to be run on a separate line from
(from usblauncher_slay.txt it looked like both lines were pasted together--perhaps your e-mail application may be
removing line endings automatically?)
e.g.
slay devb-ram
slay pps
slay usblauncher
pps -m /pps/qnx
/bin/usblauncher -h -vvvl -p 2 -t -s /lib/dll/pubs/
Cheers,
Andy
Sent: Thursday, June 19, 2014 4:54 PM
To: osmeta-core_os
Hi Andy,
OSMeta
http://community.qnx.com/sf/go/post110772
Hi Andy,
I apparently do not have a bin/usblauncher.
# ls bin/
sh           slog2info
But in my build script, it does contain the binary:
# Redirect console messages
[type=link] /bin/sh=/proc/boot/ksh
[type=link] /dev/console=/dev/ser1
[type=link] /tmp=/dev/shmem
# Programs require the runtime linker (ldqnx.so) to be at a fixed location
# Shared libraries
libc.so
libm.so.2
## Multimedia Publishing
/bin/usblauncher=usblauncher
[search=${QNX_TARGET}/etc/usblauncher]
/etc/usblauncher/rules.lua=rules.lua
/etc/usblauncher/umass.lua=umass.lua
/etc/usblauncher/usbser.lua=usbser.lua
[search=${QNX_TARGET}/armle-v7/lib/dll/pubs]
/lib/dll/pubs/pp-generic.so=pp-generic.so
#Restore search path
[search=${MKIFS_PATH}]
should i include usblauncher as a general command?
Hi Christopher,
Ok, let's try it from another angle, since you had usblauncher started somehow.
- don't mount the ram disk to / at boot up so we can rule out a problem with where /pps/qnx/device/usb_ctrl is being
written to
- start pps with -m /pps/qnx
then try the echo "start_stack::device,1" etc. as before.
If you're still having problems it may be best to arrange a screen share / WebEx through your QNX contact (portal) so
that we can walk you through the steps live.
-Andy
Sent: Thursday, June 19, 2014 5:23 PM
To: osmeta-core_os
Hi Andy,
# ls bin/
sh           slog2info
# Shared libraries
libc.so
libm.so.2
OSMeta
http://community.qnx.com/sf/go/post110774
I left everything close to the original file, except I included information for slogger2.
I performed the following commands
#pps -m /pps/qnx
#usblauncher -h -vvvl -p 2 -t -s /lib/dll/pubs/ echo "start_stack::device,1" >> /pps/qnx/usb_ctrl
However I do not see the USB Serial in the PC Device Manager, like i would if i uncommented
## USB OTG port (operating in device mode)...
## The commands below will configure the i.MX6 OTG port as a Mass Storage Device
    Example of CDC-ACM (serial) device #####
    #display_msg Configure USB Serial Device
    # Step 1 - Start USB device stack
    #io-usb-dcd -dusbser-mx6sabrelite-ci ioport=0x02184000,irq=75
    #waitfor /dev/io-usb-dcd/io-usb 4
    #waitfor /dev/io-usb-dcd/devu-usbser-mx6sabrelite-ci.so 4
    # Step 2 - Start USB CDC-ACM function driver and enable USB soft connect
    #devc-serusb_dcd -e -v -F -s -d iface_list=0,unit=1
    #waitfor /dev/serusb1 4
    #ulink_ctrl -l 1
Attachment: Text usblauncher_restartpps.txt 11.49 KB
So when using usblauncher, how can I verify the descriptors on the QNX has accepted my descriptors and strings from
rules.lua.
Thanks in advance.
Hi Christopher,
I think we'll be able to help you best through a WebEx where we can issue the commands and walk you through the steps
live. Would that be possible?
Andy
Sent: Thursday, June 19, 2014 7:59 PM
To: osmeta-core_os
rules.lua.
Thanks in advance.
OSMeta
http://community.qnx.com/sf/go/post110777
Hi Christopher,
#pps -m /pps/qnx
#### echo must be on a new line
The next step is to confirm that the text echoed to /pps/qnx/usb_ctrl is processed by usblauncher.
When it's working you'll see output similar to this:
# echo "start_stack::device,1" >> /pps/qnx/device/usb_ctrl
Jan 01 00:08:05.054    5    12   100 CMD: start_stack device,3
Jan 01 00:08:05.054    6    12   100 cmd_status::0 (No error)
Jan 01 00:08:05.054    5    12   100 Launch io-usb-dcd -d -dusbser-mx6sabrelite-ci ioport=0x02184000,irq=75 -n /dev/otg/
io-usb-dcd
Jan 01 00:08:05.054    5    12   100 CMD: start_stack error No error
Jan 01 00:08:05.059    5    12   100 Driver io-usb-dcd has pid 639002
Right now I don't think any of these log messages show up on your target which means usblauncher doesn't receive the PPS
 command to start the device stack.
If you could submit a standard support case, with reference to this post our support team can help you further.
Best regards,
Andy
Sent: Thursday, June 19, 2014 6:04 PM
To: osmeta-core_os
#pps -m /pps/qnx
    #ulink_ctrl -l 1
OSMeta
http://community.qnx.com/sf/go/post110776
Hi Andy,
I think almost got to your expected result after performing
echo "start_stack::device,1">>/pps/qnx/usb_ctrl
However, the usb_ctrl is in the "device" folder after usblauncher is enabled so i did
echo "start_stack::device,1">>/pps/qnx/device/usb_ctrl
and i received the following:
# echo "start_stack::device,1">>/pps/qnx/device/usb_ctrl
# DLL Error Library cannot be found
 FAILED  - io_usb_dlopen
unable to load dll devu--dusbser-mx6sabrelite-ci
In function usbdc_attach_hub -- /builds/660_SDP/svn/hardware/support/publishers/usblauncher/dcd.c:247 device_root_hub !=
 NULL -- assertion failed
Thanks.
Hi Christopher,
My apologies. I gave you the wrong path, yes it should be /pps/qnx/device/usb_ctrl not /pps/qnx/usb_ctrl
I see an issue in your Device_Stack cmd string:
Try again but remove the extra '-d' as this is incorrect syntax.
-Andy
Sent: Friday, June 20, 2014 12:07 PM
To: osmeta-core_os
Hi Andy,
Thanks.
OSMeta
http://community.qnx.com/sf/go/post110790
Hi Andrew,
Thanks for your help.  It seems like it is working fine now, I am able to see devices being displayed in the PC Device
Manager.
However, I am unable to switch between devices when using
echo "start_stack::device,1">>/pps/qnx/device/usb_ctrl, where 1 can change to none, 2, 3, ....
It seems like i have to slay usblauncher and re-enable usblauncher with the device that i want.  Is there something i
should consider when changing devices?
Thanks for all of your help.
Chris.
Hi Chris,
Try
echo "start_stack::none">>/pps/qnx/device/usb_ctrl
echo "start_stack::device,2">>/pps/qnx/device/usb_ctrl
echo "start_stack::device,3">>/pps/qnx/device/usb_ctrl
slaying usblauncher is not necessary.
Note that "start_stack::none" is the correct syntax; "start_stack::device,none" is not.
-Andy
Sent: Friday, June 20, 2014 4:23 PM
To: osmeta-core_os
Hi Andrew,
Manager.
Chris.
OSMeta
http://community.qnx.com/sf/go/post110797
Re: RE: RE: RE: RE: USB Device - usblauncher unable to update from *.lua files
That's it....
Thanks again...
