12/16/2007 8:11 AM
post3809
> I'm using QNX4 to controll many of our testbenches on 25 Node network.
> Now I plan to switch over to Neutrino.
> To test some things (especially qnet), I have connected 2 Neutrino computers
> called nto1 and nto2.
> I started qnet and I can access nto2 from nto1.
> So far everything is ok, but
> - when I call sin -n nto2 from nto1 the program >crashes with a core dump
> - when I call pidin -n nto2 I get the list but sometimes (often) the output
> stops for about 10 seconds and continues after that delay.
> - I have started a small server prog on nto2. Then I connect a client, which
> runs on nto1, to the server. The client sends 1000 requests to the server (
> message length 4 byte). To see what happens the server prints out the number
> of the current request. The output stops after a certain number of request (
> again for about 10 secs) continues, stops again, continues....
> What is the reason for that delays?
> Thanks
> Norbert
Hello Norbert,
Perhaps, this would have been better placed in some networking forum.
http://community.qnx.com/sf/discussion/do/listForums/projects.networking
Even then the experts there would need more detailed informations such as :
-used OS Version and patchlevel
-target (x86, ppc ....?)
-how did You started which qnetstack (l4 or compat or both)?
Did You tried command-line options to Your qnet ?
Exact network topology (crossover, switches bridges etc ...) ?
Outputs of:
qconfig (from your Dev-Host, if avaliable from Your target)
uname -a
nicinfo
pidin -p io-net
ls /dev/io-net/
cat /proc/qnetstats during after Your pidin hang/delay ?
This would be at least a starting point.
for example try :
#sin toomuch
or
#sin sin
J
So that is sin under nto.
Hope this helps.
Jeevan
