Re: compiling core_os with 4.2.1 and errors
11/27/2007 11:07 PM
post3008
Thanks that solved the problem, new one now
/usr/local/src/qnx/src/core_os/lib/malloc/dbg/mtrace.c: In function 'mtrace':
/usr/local/src/qnx/src/core_os/lib/malloc/dbg/mtrace.c:751: warning: the address of '__malloc_trace_filename' will never
be NULL
/usr/local/work/qnx632/host/linux/x86/usr/bin/qcc -V4.2.1,gcc_ntoarm -c -O -Wc,-Wall -Wc,-Wno-parentheses -Wc,-fno-
builtin -DMALLOC_WRAPPER -D_LIBMALLOC -DMALLOC_DEBUG -I/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g -O2
-I. -I/usr/local/src/qnx/src/core_os/lib/malloc/arm/so.be -I/usr/local/src/qnx/src/core_os/lib/malloc/arm/so.g.be -I/
usr/local/src/qnx/src/core_os/lib/malloc/arm -I/usr/local/src/qnx/src/core_os/lib/malloc -I/usr/local/src/qnx/src/
core_os/lib/malloc/dbg -I/usr/local/src/qnx/src/core_os/lib/malloc/common -I/usr/local/src/qnx/src/core_os/lib/c/alloc -
I/usr/local/src/qnx/src/core_os/lib/malloc/public -I/usr/local/src/qnx/stage/usr/include -I/usr/local/work/qnx632/target
/qnx6/usr/include -g -EB -shared -DVARIANT_so -DVARIANT_g -DVARIANT_be -Wc,-fno-strict-aliasing /usr/local/
src/qnx/src/core_os/lib/malloc/dbg/new.cc
In file included from /usr/local/src/qnx/stage/usr/include/stdlib.h:36,
from /usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc-lib.h:26,
from /usr/local/src/qnx/src/core_os/lib/malloc/dbg/new.cc:30:
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h: In member function 'int CheckedPtr<T>::operator==
(const T*)':
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:192: warning: no return statement in function
returning non-void
(CheckedPtr<T>)':
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:193: warning: no return statement in function
returning non-void
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h: In constructor 'CheckedPtr<T>::CheckedPtr(T*)':
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:203: error: there are no arguments to '_mptr' that
depend on a template parameter, so a declaration of '_mptr' must be available
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:203: error: (if you use '-fpermissive', G++ will
accept your code, but allowing the use of an undeclared name is deprecated)
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:206: error: there are no arguments to '_musize' that
depend on a template parameter, so a declaration of '_musize' must be available
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h: In member function 'CheckedPtr<T>& CheckedPtr<T>::operator=(T*)'
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:217: error: there are no arguments to '_mptr' that
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:220: error: there are no arguments to '_musize' that
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h: In member function 'T& CheckedPtr<T>::operator*()':
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:234: error: there are no arguments to
'malloc_warning' that depend on a template parameter, so a declaration of 'malloc_warning' must be available
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:239: error: there are no arguments to
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h: In member function 'T* CheckedPtr<T>::operator->()':
/usr/local/src/qnx/src/core_os/lib/malloc/public/malloc_g/malloc.h:249: error: there are...
