Trackers
Trackers
Forum Topic - QNX6.6 BSP cannot work on MCIMX6Q-SDB: (2 Items)
hi all,
QNX6.6 BSP(Freescale i.MX6Q Sabre Board for Smart Devices) cannot work on my MCIMX6Q-SDB board.
Welcome to QNX Neutrino Initial Program Loader for Freescale i.MX6Q Sabre-Smart)
SDMMC download...
load image done.
Found image               @ 0x18000008
Jumping to startup        @ 0x108068F8
�SCU_CONFIG = 00005503, 4 cpus
L2 cache enabled
CPU0: L1 Icache: 1024x32
CPU0: L1 Dcache: 1024x32 WB
CPU0: VFP-d32 FPSID=41033094
CPU0: NEON MVFR0=10110222 MVFR1=01111111
CPU0: 412fc09a: Cortex A9 MPCore rev 10 792MHz
Detected i.MX6 Dual/Quad, revision TO1.2
PLL1 - System     : 792MHz
PLL2 - System Bus : 528MHz
PLL3 - OTG USB    : 480MHz
PLL4 - Audio      : 36MHz
PLL5 - Video      : 339MHz
PLL7 - Host USB   : 480MHz
PLL8 - Enet       : 50MHz
IPG clock     : 66000000Hz
IPG per clock : 66000000Hz
UART clock    : 80000000Hz
CSPI clock    : 60000000Hz
AHB clock     : 132000000Hz
AXI clock     : 264000000Hz
EMI_SLOW clock: 29333333Hz
DDR clock     : 528000000Hz
USDHC1 clock  : 198000000Hz
USDHC2 clock  : 198000000Hz
USDHC3 clock  : 198000000Hz
USDHC4 clock  : 198000000Hz
ENFC clock    : 24000000Hz
decompressing...done
CPU1: L1 Icache: 1024x32
CPU1: L1 Dcache: 1024x32 WB
CPU1: VFP-d32 FPSID=41033094
CPU1: NEON MVFR0=10110222 MVFR1=01111111
CPU1: 412fc09a: Cortex A9 MPCore rev 10 792MHz
CPU2: L1 Icache: 1024x32
CPU2: L1 Dcache: 1024x32 WB
CPU2: VFP-d32 FPSID=41033094
CPU2: NEON MVFR0=10110222 MVFR1=01111111
CPU2: 412fc09a: Cortex A9 MPCore rev 10 792MHz
CPU3: L1 Icache: 1024x32           ...
Re: QNX6.6 BSP cannot work on MCIMX6Q-SDB
ello, have you resolved this already?
I am also seeing similar issue with SABRE AI (MCIMX6QAICPU1), and it is currently blocking me to go further.
Writing QNX 6.6 BSP image on SD card, booting from SD and it seems that it cause fault? in the middle of boot sequence
and do "Welcome to .." again.
I my case, the console looke like below:
Quad/Dual/DualLite/Solo/QuadPlus Sabre-ARD RevB (ARM Cortex-A9 MPCore)
i.MX6 Quad or Dual CPU detected.
Command:
Press 'D' for serial download, using the 'sendnto' utility
Press 'M' for SDMMC download, IFS filename MUST be 'QNX-IFS'.
SDMMC download...
sdmmc_highspeed:  Switch to high speed mode successful
Load QNX image from SDMMC...
load image done.
Found image               @ 0x11800008
Jumping to startup        @ 0x1080A690
(then, "Welcome to QNX xxxx" and the same lines are printed out)
