05/12/2009 10:38 AM
post29266
Hi everyone,
I'm having an weird problem in the boot process of QNX 6.3.0 SP3 on a AMD Geode LX800 board.
Every 10 out of 1000 (1%) of the boots fail.
It fails just after starting the OS image created with the build below.
The screen output looks like:
QNX 6.3.0 SP3"
---> Starting PCI Services
Can't locate PNP bios (No errors)
---> Starting Console Manager
Unable to start "devc-con" (8)
Unable to access "/dev/con1" (2)
---> Starting EIDE Driver
Unable to start "mount" (8)
---> Starting /etc/system/sysinit
and it hangs here. This happens in 1% of the boots.
Does anyone have an idea of what could cause this? We have experienced this behaviour in 2 boards.
Leonel
Build file used to create the image:
[virtual=x86,bios +compress] boot = {
# Reserve 64k of video memory to handle multiple video cards
startup-bios
# PATH is the *safe* path for executables (confstr(_CS_PATH...))
# LD_LIBRARY_PATH is the *safe* path for libraries (confstr(_CS_LIBPATH))
# i.e. This is the path searched for libs in setuid/setgid executables.
PATH=/proc/boot:/bin:/usr/bin:/opt/bin:/sbin:/usr/sbin:/opt/sbin LD_LIBRARY_PATH=/proc/boot:/lib:/usr/lib:/lib/dll:/opt
/lib procnto
[+script] startup-script = {
display_msg " "
display_msg "QNX 6.3.0 SP3"
display_msg " "
procmgr_symlink ../../proc/boot/libc.so.2 /usr/lib/ldqnx.so.2
display_msg "---> Starting PCI Services"
seedres
pci-bios &
waitfor /dev/pci
display_msg "---> Starting Console Manager"
devc-con -n2
waitfor /dev/con1
reopen /dev/con1
display_msg "---> Starting EIDE Driver"
devb-eide blk noatime auto=partition dos exe=all cam quiet
# Mount one QNX 4 filesystem as /, and another as /home.
# Also, mount a DOS partition and the CD drive.
waitfor /dev/hd0
mount /dev/hd0t79 /
# display_msg "---> Starting Pipe, Slogger & Queue Services"
# slogger
# pipe
# mqueue
display_msg "---> Starting /etc/system/sysinit"
ksh -c /etc/system/sysinit
libc.so
libcam.so
io-blk.so
cam-disk.so
fs-qnx4.so
[data=c]
seedres
pci-bios
devb-eide
ksh
devc-con
mount
