Fundamental Architecture Question
03/25/2009 3:08 PM
post25235
Starting to lay down the design of a system (single CPU, single application) that will basically have to do the
following:
communicate with "outside" world via radio data link
communicate with "internal" pieces via RS-232
manage messaging, data transformation, etc between the internal pieces & outside world
internal pieces subject to change (new hardware for instance)
One of the problems/issues I am having is that after digging thru the docs for the past 7 - 10 days; I am stiil not
convinced that I understand the relationships between partitions, processes and threads. Seems as if partitions have
processes which in turn have threads (or some combination thereof). For example, I want the external I/O to have its own
time slice (partition) and address space (process) and within it have thread(s) sitting on the input ports and moving
message data to/from another area (partition/process/thread(s)) which does the work.
Does this make sense from a QNX 6.4 standpoint or am I missing something (or maybe a lot of somethings).
Thanks for any light you may be able to shed
Re: Fundamental Architecture Question
03/25/2009 3:27 PM
post25242
Hello Andrew,
the relationships between processes and threads is well described here
http://www.qnx.com/developers/docs/6.4.0/neutrino/getting_started/about.html
Yuriy
RE: Fundamental Architecture Question
03/25/2009 3:50 PM
post25247
Thanks Yuriy, I have indeed read this (more than once actually); what I
did not see in there is how, or even if, processes/threads tie in with
adaptive partitions.
Cheers!
Andy
From: Yuriy Synytskyy [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 25, 2009 12:27 PM
To: momenticsgs-community
Subject: Re: Fundamental Architecture Question
Hello Andrew,
html
Yuriy
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post25242
03/25/2009 4:28 PM
post25256
Hi Andrew,
Let me give you an example. I have a target board with 3 partitions on it. One I use for drivers, one I use for a
network file system and one used for qconn. Each partition is setup to only use a specific amount of my CPU resources.
With in each partition I have started one or more processes to take care of a certain function. Each process has
threads with in it to do individual tasks. The Adaptive Partition Scheduler will make sure no process(es) goes over the
alloted CPU resource.
So real world example
My APS breakdown. Three Partitions.
sched_aps NFS 15
sched_aps QCONN 40
sched_aps INETD 10
One of my processes assigned to a partition(network driver).
[sched_aps=IONET] io-pkt-v4 -dsmc9000 ioport=0x04800000,irq=200 -p tcpip
Threads within the process that are ultimately with in the partition
3 1 roc/boot/io-pkt-v4 21r SIGWAITINFO
3 2 roc/boot/io-pkt-v4 10r RECEIVE 1
3 3 roc/boot/io-pkt-v4 22r RECEIVE 14
3 4 roc/boot/io-pkt-v4 21r RECEIVE 15
Time used by the threads will be "billed" to the partition. The scheduler in turn will make sure your Process(and in
turn your threads) do not use more time then you have given them. Of course there is a lot more to Adaptive
Partitioning when it comes to scheduling but this should give you a rough idea of how it works.
-Wade
From: Andrew Page [mailto:community-noreply@qnx.com]
Sent: Wed 3/25/2009 3:50 PM
Subject: RE: Fundamental Architecture Question
Cheers!
Andy
Hello Andrew,
html
Yuriy
http://community.qnx.com/sf/go/post25247
03/25/2009 4:37 PM
post25259
But don't forget that io-pkt-v4 threads that receive from another thread will inherit the partition of the
client.
Processes don't belong to partitions, threads do, much like only threads have priorities. A process does have
a priority value, but it's simply the original priority we requested that it was launched at - it may not
have any bearing on the real priority of any threads belonging to it.
Colin
Wade Hawkins wrote:
> Hi Andrew,
> it. One I use for drivers, one I use for a network file system and one
> of my CPU resources. With in each partition I have started one or more
> processes to take care of a certain function. Each process has threads
> will make sure no process(es) goes over the alloted CPU resource.
> sched_aps NFS 15
> sched_aps QCONN 40
> sched_aps INETD 10
> -p tcpip
> scheduler in turn will make sure your Process(and in turn your threads)
> more to Adaptive Partitioning when it comes to scheduling but this
> -Wade
> Cheers!
> Andy
> Hello Andrew,
> html
> Regards,
> Yuriy
> http://community.qnx.com/sf/go/post25256
cburgess@qnx.com
03/25/2009 4:59 PM
post25262
Ah, this was what I was missing; that processes don't belong to
partitions. In my case, then could I have the one application aka
process (we will have a single node, no networking, single CPU) which I
can "distribute" over multiple partitions running multiple threads
within the partitions? However, if I chose I could put a network driver
(say, ethernet) in it own process putting its data into a shared memory
region and then have my app pick it up and do whatever?
Andy
From: Colin Burgess [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 25, 2009 1:38 PM
will inherit the partition of the client.
have priorities. A process does have a priority value, but it's simply
Colin
Wade Hawkins wrote:
> Hi Andrew,
> on it. One I use for drivers, one I use for a network file system and
> amount of my CPU resources. With in each partition I have started one
> has threads with in it to do individual tasks. The Adaptive Partition
> Scheduler will make sure no process(es) goes over the alloted CPU
resource.
> sched_aps NFS 15
> sched_aps QCONN 40
> sched_aps INETD 10
> there is a lot more to Adaptive Partitioning when it comes to
> -Wade
> I did not see in there is how, or even if, processes/threads tie in
> with adaptive partitions.
> Cheers!
> Andy
> Hello Andrew,
> html
> Regards,
> Yuriy
03/25/2009 4:45 PM
post25260
Thanks Wade, that clears up the "time" part.
From: Wade Hawkins [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 25, 2009 1:29 PM
Hi Andrew,
sched_aps NFS 15
sched_aps QCONN 40
sched_aps INETD 10
-p tcpip
-Wade
Cheers!
Andy
Hello Andrew,
html
Yuriy
