Fundamental Architecture Question
03/25/2009 3:07 PM
post25234
Starting to lay down the design of a system (single CPU, single application) that will basically have to do the
following:
communicate with "outside" world via radio data link
communicate with "internal" pieces via RS-232
manage messaging, data transformation, etc between the internal pieces & outside world
internal pieces subject to change (new hardware for instance)
One of the problems/issues I am having is that after digging thru the docs for the past 7 - 10 days; I am stiil not
convinced that I understand the relationships between partitions, processes and threads. Seems as if partitions have
processes which in turn have threads (or some combination thereof). For example, I want the external I/O to have its own
time slice (partition) and address space (process) and within it have thread(s) sitting on the input ports and moving
message data to/from another area (partition/process/thread(s)) which does the work.
Does this make sense from a QNX 6.4 standpoint or am I missing something (or maybe a lot of somethings).
Thanks for any light you may be able to shed
