Trackers
Trackers
Forum Topic - SDP fails to start: (11 Items)
SDP fails to start
I'm trying to get QNX SDP 6.4.0 to start but keep running into segfaults.  After running run_qde.sh in /opt/qnx640 I see
 the Momentics/Eclipse splash screen come up and can select where my workspace should go.  A few seconds after this it
crashes with this:
*** glibc detected *** /opt/qnx640/host/linux/x86/usr/qde/eclipse/qde: realloc(): invalid pointer: 0x6e70735b ***
======= Backtrace: =========
/lib/libc.so.6[0x3eb3a4]
/lib/libc.so.6(realloc+0x242)[0x3efdc2]
/usr/lib/xulrunner-1.9/libxul.so[0xaf6aa99d]
/usr/lib/xulrunner-1.9/libxul.so[0xaf6aab05]
/usr/lib/xulrunner-1.9/libxul.so[0xaf6aae02]
/usr/lib/xulrunner-1.9/libxul.so[0xaf6ab5cd]
/usr/lib/xulrunner-1.9/libxul.so[0xaf67dc16]
[0x6b546d00]
The memory map is also printed (many lines of output) and followed immediately with this message:
/usr/libexec/Momentics: No such file or directory.
My host system runs Fedora Core 10 which I see is not officially supported but it seems like it should work.  If anyone
can provide some advice I'd appreciate it.
Dave
Re: SDP fails to start
There are some problems with eclipse support with regards to xulrunner library. Try to update the library (xulrunner).
see the Momentics/Eclipse splash screen come up and can select where my workspace should go.  A few seconds after this
it crashes with this:
> [0x6b546d00]
anyone can provide some advice I'd appreciate it.
> Thanks,
> Dave
> http://community.qnx.com/sf/go/post24382
I updated to the latest version of xulrunner and now I get this error when run_qde.sh crashes.
Anything else in the log? Can you do
env | grep libexec
> http://community.qnx.com/sf/go/post24521
Where can I find the log file?  Running the command you suggested returns the following:
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
I searched my entire computer for a file called Momentics but could not find one.  Is it something that should have been
 included as part of the install?
I have no ide what prints this message, that is why I asked for more log. What are the other symptoms?
I'm not sure what other log files to consult.  The only symptom is the entire application crashing.  The splash screen
status says its loading the workbench.  What else can I check?
I did find a bug buddy crash dump file.  Maybe this will help.
Attachment: Text Momentics-bugreport.txt 27.65 KB
This is still xul library crashing, we posted several workarounds before on the forum, can you please for "xulrunner
eclipse" on this forum on the net
I got the exactly same problem after installing Momentics on Fedora 9. Have we got a solution for this issue?
I got one way to be around this problem.
Basically, I first uninstaled xulrunner and all others has dependency on it, the whole list the followings then
Momentics starts to work,
  Erasing        : yelp                                            [ 1/13]
  Erasing        : eclipse-cdt                                     [ 2/13]
  Erasing        : eclipse-cdt-sdk                                 [ 3/13]
gconfd-2: no process killed
  Erasing        : gnochm                                          [ 4/13]
  Erasing        : xulrunner                                       [ 5/13]
  Erasing        : eclipse-rcp                                     [ 6/13]
  Erasing        : eclipse-platform                                [ 7/13]
  Erasing        : eclipse-cvs-client                              [ 8/13]
  Erasing        : devhelp                                         [ 9/13]
  Erasing        : xulrunner-devel                                 [10/13]
  Erasing        : libswt3-gtk2                                    [11/13]
  Erasing        : firefox                                         [12/13]
  Erasing        : totem-mozplugin                                 [13/13]
Then I reinstalled all the listed package, and Momentics can still work. It seems that
I am not clear the cause, I notice that Momentics 6.4 is based on Eclipse platform 3.3.2. Right now on my machine, both
Momentics 6.4 and Eclipse 3.3.2 work, but Eclipse 3.4.2 stop working.
