Forum Topic - Momentics 3.0.0 java development: (2 Items)
OK I have been trying to get started on some java development on my momentics ide. I have installed the Eclipse java
development tools and all the supporting plugins that the updater prompted me to get.
So I go to the preparing the workbench in the basic tutorial under java development. I then proceed to verify that I
have a JRE selected to use when I run my programs. I am running eclipse at this point so I obviously have a JRE some
where, but for the life of me I can't find one using the search button nor can I explicitly add it when I try to direct
it to the JRE that pidin says eclipse is using. How can I make eclipse use the JRE that is active? Also I have already
downloaded the IBM j9 stuff and eclipse says that it doesn't recognize anything in the folder as a JRE.
Re: Momentics 3.0.0 java development
Here is instruction how to set up j9 for eclipse as JRE for windows, I think it should be similar for Neutrino
http://www.post1.net/lowem/entry/ibm_j9_jdk_in_eclipse
> http://community.qnx.com/sf/go/post20623
