Re: Installing QNX 6.2 after QNX 6.3 on Windows
12/16/2008 9:20 AM
post18694
You trying to use IDE from 6.3.2 to work with 6.2.1 tools? You can add fake configuration file, so IDE has a switch i.e.
copy xml from $QNX_CONFIGURATION and set paths to ones that needed for 6.2.1. Y
ou can also try to override environment variables before you start IDE (see FAQ http://community.qnx.com/sf/wiki/do/
viewPage/projects.ide/wiki/IDEGeneralFAQ).
Sunil Keshava wrote:
> Hello,
> I have a Windows XP (SP2) PC which had QNX 6.3 compiler and IDE installed. I then installed QNX 6.2 (had to work on a
different project) without uninstalling the existing 6.3. I wanted to know if this is allowed as I have been facing few
problems while switching between QNX
> 6.3 and 6.2.
> The Configuration tool in 6.3 does not list QNX 6.2 as an option. I have to manually change the Host Files and Target
Files options for "Custom"
> in the Configuration tool each time I switch from 6.3 to 6.2. Is there an easier way to solve this problem?
> Thanks
> Sunil
> http://community.qnx.com/sf/go/post18679
01/02/2009 12:33 PM
post19314
Hi Sunil,
QNX Momentics 6.3.0 cannot coexist with version 6.2.0. It can coexist with version 6.2.1 and later.
If you tried installing 6.3.0 on top of 6.2.0, the installer would display proper error message.
Natalia
> Hello,
> then installed QNX 6.2 (had to work on a different project) without
> been facing few problems while switching between QNX
> 6.3 and 6.2.
> manually change the Host Files and Target Files options for "Custom"
> Thanks
> Sunil
