Re: Error when building OS image for ml403 BSP
11/18/2008 8:57 AM
post16744
> I only found the libinput.a, added it as you said. I still got the error. If I close the bsp-
xilinx_virtex4_ml403_devi-ml300 project (I selected all entries as importing), everything is OK.
Well I am not sure it is ok, you will be missing this driver in the OS image... You sure you specified right library
path?
> By the way, could you briefly tell me how can I download my application to the board after transferring Bitstream
file and OS image?
Briefly: ftp, scp, tftp or qconn (IDE - Target File System Navigator).
> Does the OS image include my application?
Well depends if you include it or not. It is easy to include it - in system builder project you add binary using "Add
Binary" button and locate your binary
in the other project.
