Re: Steps to get a bootable .ifs file?
11/14/2008 7:10 AM
post16566
Well, I don't remember the exact error messages, but IIRC,
they were driver related. (I will recreate the error situation and
post the error message shortly)
So, the .build file had to be modified a bit (to 'reopen' the
console driver). Also, a 'hello world' executable was inserted
into /proc/boot directory.
Now, the image boots, and also displays the 'hello world' message :-)
Then I am sent to a shell (esh). And commands that have been
included into the build file can be run from there.
Next, I tried to use the same dinit command to write the image to
a flash drive (pendrive). But that did not work out. I guess I have
to look into the docs to see if I should be using a separate command
for that instead of dinit. So, my next goal is to get the same (hello world)
effect by booting from a pendrive.
Santanu Chatterjee
