QNX Momentics 6.3.2 fails to install on Linux host
11/04/2008 11:51 PM
post15943
I am having trouble installing QNX Momentics 6.3.2, seemingly due to Java problems. I've seen similar issues posted but
the resolutions for those cases do not fix my situation. My host is running OpenSUSE 11.0. Hearing of issues with
that distribution's packaging of Java, I removed all versions and reinstalled the JVM directly from Sun's website. Here
are the two install scenarios I've tried; both of which fail:
1) running momentics-6.3.2-200709062316-linux.bin from shell prompt as root
Install Shield fails with the following message:
Preparing Java(tm) Virtual Machine...
<repeats>
Exception in thread "main" java.lang.OutOfMemoryError
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at run.main(run.java:38)
2) extracting qnx_linux_setup.jar from .bin file and running as java -jar qnx_linux_setup.jar
Here, the installer starts up and I can enter my key and designate the installation directory. After being told how
much drive space will be used, the progress bar moves to 2% and then displays this message:
The uninstaller has not been created completely. At least one of these files is missing:
uninstall.dat, uninstaller.jar, and uninstaller.bin.
I click on the next button and see this message:
Errors occurred during the installation.
JVM not found
At this point all I can due is abort the installation. Other Java applications execute correctly on my system. Any
advice on getting past this hurdle would be most appreciated.
Dave
