10/20/2008 3:10 AM
post15216
Hello!
I had installed QNX Momentics Development Suite 6.3.2 in Windows XP. IDE 4.0.1
Trying to make the first project of C++.
Program text:
#include <stdio.h>
int main(void) {
printf("Welcome\n");
return 0;//EXIT_SUCCESS;
Selected Project type: QNX C/C++.
Build Variants: x86 (debug, release)
Compiler Type: GNU 3.3.5
Linker -> Category: General Options
Make Builder -> marking Use default, Build (Incremental Build), Clean
Build Project had no mistakes.
Select Windows -> Customize Perspective -> Launch
Run -> Debug:
Launch Configuration: C/C++ Local Application
Main -> C/C++ Application: x86/o-g/new_project_g
Debugger -> Debugger: gdb/mi
Stop on startup at: main
Main -> GDB Debugger: gdb
GDB Command Set: CygWin
Protocol: mi
Shared Libraries -> load automatically
Source -> Source Lookup Path: Default
After pressing Apply, Debug the error window appears:
Error creating session
Exec error: Launching failed (3 lines)
Trying to change Debugger: CygWin Debugger, gdb Debugger
GDB Command Set: Standard, Standard (Windows)
I’ve got the same error.
What can be changed (added, deleted)?
