Forum Topic - Folders in Momentics: (3 Items)
I have made small projects in Momentics based on the QNX C++ project and now feel ready to move onto cleverer things.  I
 added a folder and some source files to it and and want to get that code to compile too.  When I build the project,
only the files in the root folder build.
I have looked around on the Internet and seen documents about make files and recurse files and compiler settings etc but
 I don't feel that should be necessary simply to compile files that are in folders.
Can you help?
Many thanks,
Ant
AW: Folders in Momentics
Hi Ant,
in the C/C++ perspective, open your project's context menu
and hit "Properties..." (at the very bottom).
From the list on the left of the dialog popping up, choose
"QNX C/C++ Project", then select the "Compiler" tab.  At
the top, there's a combo box labelled "Category:" -- select
"Extra sources paths" here.
You'll be presented an (empty) list and a couple of buttons
to add extra paths with. To use a subfolder in your project,
press the "Project..." button, then select your project
subfolder in the little tree opening up and hit Ok...
Kind regards,
- Thomas Haupt
> -----Ursprungliche Nachricht-----
> Von: Ant Pace [mailto:community-noreply@qnx.com]
> Gesendet: 01 October 2008 15:28
> An: momenticsgs-community
> Betreff: Folders in Momentics
> get that code to compile too.  When I build the project, only
> make files and recurse files and compiler settings etc but I
> Can you help?
> Many thanks,
> Ant
> http://community.qnx.com/sf/go/post14305
Re: AW: Folders in Momentics
Found it!  Great, thanks.
Ant
