Multiple boot configurations
08/08/2008 2:35 PM
post11590
I want to have both a Neutrino target and Momentics IDE environment on the same disk on separate partitions. I've
already tried this, but cratered.
First I installed the x86 runtime on a 200MB partition. Booted without trouble and connected to a Windows based IDE
using qconn.
Next I installed Momentics Dev Suite on a 2GB partition. It seemed to run fine the first time, but now keyboard input is
failing and it fails to boot normally. We've managed to get a login back from a remote serial console.
We've seen the following log:
sh: j_init: tcgetpgrp() failed: Inappropriate I/O control operation
sh: warning: won't have full job controldev/ser1ter.
Fri Aug 8 01:38:22 2008 on /dev/ser1 change your environment.
Last login: Fri Aug 8 01:14:57 2008 on /dev/ser1.
edit the file .profile if you want to change your environment.
To start the Photon windowing environment, type "ph".er.
Is there direction to fix the Photon / Momentics environment? Can I infact run separate OS on different partitions?
