Forum Topic - example how to use io-net master/slave udp process:
Hi
I'm newbie in QNX environment and C developing.
Where can i find a small and simple example to create 2 processes, master and slave, that send udp packet using io-net
socket?
Alessio
RE: example how to use io-net master/slave udp process
Hi Alessio:
	In this case, Google is your friend.  The socket interface in
Neutrino is based on BSD, so pretty much any UNIX example code that you
find should work for you.
Let me know if you can't find any links and I'll dig some up for you.
	Robert.
From: alessio fabbri [mailto:alessio.fabbri@alfaec.it]
Sent: Wednesday, July 23, 2008 9:34 AM
To: momenticsgs-community
Subject: example how to use io-net master/slave udp process
Hi
master and slave, that send udp packet using io-net socket?
Alessio
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post10885
