Forum Topic - compilation error in QNX:
I'm running QNX 6.3.2 in VMWare, and building C++ libraries built using Unix scripts.
But when I try to build my QNX C++ project with this library, libbdb_cxx-4.7.a, I get the below compilation errors.
Any ideas on how to resolve this? I've tried adding #include <stdio.h>, using std::cout in the source files but no luck.
Thanks for any help you can provide.
D:/QNX632/ide4-workspace/MyRecord/lib/libdb_cxx-4.7.a(cxx_db.o): In function `_verify_callback_c':
cxx_db.o(.text+0x14d2): undefined reference to `ostream::operator<<(char const *)'
D:/QNX632/ide4-workspace/MyRecord/lib/libdb_cxx-4.7.a(cxx_env.o): In function `DbEnv::_stream_error_function(__db_env
const *, char const *, char const *)':
cxx_env.o(.text+0x1cc2): undefined reference to `ostream::operator<<(char const *)'
cxx_env.o(.text+0x1cd2): undefined reference to `ostream::operator<<(char const *)'
cxx_env.o(.text+0x1ce5): undefined reference to `ostream::operator<<(char const *)'
cxx_env.o(.text+0x1cf8): undefined reference to `ostream::operator<<(char const *)'
D:/QNX632/ide4-workspace/MyRecord/lib/libdb_cxx-4.7.a(cxx_env.o)(.text+0x1d56): more undefined references to `ostream::
operator<<(char const *)' follow
cc: D:/QNX632/host/win32/x86/usr/bin/ntox86-ld caught signal 1
make[2]: *** [D:/QNX632/ide4-workspace/MyRecord/x86/o/MyRecord] Error 1
make[2]: Target `all' not remade because of errors.
make[2]: Leaving directory `D:/QNX632/ide4-workspace/MyRecord/x86/o'
make[1]: [all] Error 2 (ignored)
make[1]: Leaving directory `D:/QNX632/ide4-workspace/MyRecord/x86'
Any ideas on why I'm getting these errors in the cxx_db.cpp and also the cx_env.cpp (and other) files?
Re: compilation error in QNX
In you linker line do you have -lang-c++ option?
Unix scripts.
const *)'
function `DbEnv::_stream_error_function(__db_env const *, char const *, char
const *)':
const *)'
const *)'
const *)'
const *)'
6): more undefined references to `ostream::operator<<(char const *)' follow
> http://community.qnx.com/sf/go/post8615
Yes I have that option in the linker.
I just commented out the few lines of code containing "<<" and am now able to build my library and can run my C++
application on QNX Neutrino RTOS now.
thanks.
What is your compile/link line like?
What sort of stream operators were not linking?
to build my library and can run my C++ application on QNX Neutrino RTOS now.
> thanks.
> http://community.qnx.com/sf/go/post8624
cburgess@qnx.com
I just tried the -lang-c++ addition to the linker line and it fixed my problem.
Thanks!
