AW: Problems with QNX or to stupid?
05/23/2008 9:17 AM
post8402
Hmmm strange. Can You post the output of
qconfig
command from out of Your Windows DOS cmd-shell ?
And the output of
uname -a
and if possible
qconfig
from Your target ?
Just want to exclude a host - target version mismatch.
Jeevan
-----Ursprüngliche Nachricht-----
Von: Vielstädte Carsten []
Gesendet: Freitag, 23. Mai 2008 11:21
An: momenticsgs-community
Betreff: Problems with QNX or to stupid?
Hallo,
I'm new to QNX and have a difficult problem or maybe not.
I am using a QNX Host on a x86 Plattform and a Windows XP Host system.
When connecting the Momentics IDE with the Hostsystem (qconn) the "Hello
World" Programm is running in the IDE.
But when i starting the programm in the shell on my QNX Host, i getting this
error message. "Memory fault (core dumped)".
I hope anybody knows this problem and can help me.
Carsten
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post8397
Re: Problems with QNX or to stupid?
05/23/2008 9:55 AM
post8403
Have you modified the program at all? If you run it from IDE if it
actually crashes error message would not be visible.
Vielstädte Carsten wrote:
> Hallo,
this error message. "Memory fault (core dumped)".
> Thanks
> Carsten
02/26/2012 1:01 AM
post91786
It looks like I ran into the same problem.
I have qnxsdp-6.5 installed on my host pc (Vista), and installed QNX on VMware player 4.0.
run qconfig on host pc:
QNX Installations
Installation Name: QNX Software Development Platform 6.5.0
Version: 6.5.0
Base Directory: C:/QNX650
QNX_HOST: C:/QNX650/host/win32/x86
QNX_TARGET: C:/QNX650/target/qnx6
Additional Packages
run qconfig on qnx
QNX Installations
Version: 6.5.0
Base Directory: /usr/qnx650/
QNX_Host: /usr/qnx650/host/qnx6/x86
QNX_target: /usr/qnx650/target/qnx6
The default c++ QNX project can be compiled and run from IDE OK, and I can see the program out "Welcome to the QNX
Momentics IDE". but when I transfer the executable file to qnx, and run it from the terminal, I got memory fault (core
dumped) message.
If I transfer the source file (.cc) files to qnx and compile the source file on QNX instead of IDE, the binary file can
run without memory fault.
