12/03/2012 9:41 AM
post97717
gdbserver built for linux won't help because qnx is not linux.
You can do standard "QNX Attach to Running Process" launch configuration.
* Create a fake makefile project, as location specify location of your
project on disk (pre-built)
* Open Run->Debug Configurations...
* Select "QNX Attach to Running Process" debug configuration, press New
button
* Select your binary, click Debug (If you have your shared libs set
paths in Debug tab first).
* Select you process (that should match your binary) and click ok.
* It attaches in random place. Place continue to hit your breakpoints if
you set any.
On 12-12-01 04:53 PM, Ivan Not specified wrote:
> I want to debug application which is running on target. The application is build using jam based build system, so I
don't have project which I can open in IDE. I haven't found the way to debug application using IDE if IDE wasn't used in
build process (I'm sorry, if I am wrong, I'm new to the IDE, just let me know if I should try again). My idea was to
use gdb server. I've build it under linux using cross compiler from QNX installation disk, but I can't connect to it for
some reason. Could you share your experience concerning debugging without IDE.
> Thanks in advance
> http://community.qnx.com/sf/go/post97710
> To cancel your subscription to this discussion, please e-mail momenticsgs-community-unsubscribe@community.qnx.com
