Re: QNX6.5 SP1 minimal runtime installation
04/24/2013 10:16 AM
post100844
Dear All,
I could not find the post option in this forum. Hence, i am posting my query here since i am facing the problem with
QNX6.5 SP1. The below is my query,
1) I am trying to port QNX 6.5.0 OS to my Intel top-cliff board.
2) I have downloaded qnxsdp-6.5.0-x86-201007091524-nto.iso file and tried to install in the following ways
a) I tried to boot into live boot option (F2), it always shows "/etc/system/sysinit : No such file or directory."
b) I tried to install it on my hard-disk with partition type as 179 it is also shows missing some file.
But when I use the same CD on my development PC for virtual box Qnx OS installation. It gets installed successfully.
Any clue on this issue that any settings is missing?
3) I have downloaded Intel crown-bay source and built the IFS images by following the below mentioned steps
- Typed "make" in the src root directory.
- mkifs -v -r ../install crownby.fastboot.usb.build custom.ifs
- The above step created a ifs file and used the same for following steps
- connected a USB drive in virtual box where Qnx is installed.
- fdisk /dev/umass0
- Deleted all existing partitions, and created a QNX partition of type 79, used the entire USB
Memory stick
- Made this partition as bootable
- Saved the configuration and exited
- To restart the associated devb-umass driver slay devb-umass and devb-umass command issued at the terminal
-To Initialize the USB disk -dinit –hq /dev/hd1t79 command used
- USB disk is mounted as follows mount –t qnx4 /dev/hd1t79 /fs/usb0
-Finally the built IFS file copied as follows cp custom.ifs /fs/usb0/.boot
But it shows only hit esc for .altboot and continued with dots when I booted in the board, then its hangs continuously.
So please someone help me to debug the issue.
david.
