Forum Topic - What is the right Java version to install SDKs?: (2 Items)
Dear ALL,
I have a windows 7 Home Premium(x64) Eng installed laptop.
I have Momentics 4.7 installed on my computer, but I want to install the new service pack which is QNX 6.5 Service Pack1
I have been recieved below error since I have been evaluating QNX 6.4.1 and upper. Can anyone tell me what is the right
java version should be installed on a compuer. If you know it, can you please share the link with me.
I don't want to recieve below error and fix it using "-is:extract" command to install new version.
An unhandled error occured -- specify system property "is.debug" for more information.
My Java versions :
-Java (TM) 6 Update 33
-Java (TM) SE Development Kit 6 Update 26
-J2SE Run Time Enviroment 5.0 Update 5
Looking forward to your comments.
Re: What is the right Java version to install SDKs?
SDP 6.5.0 installation comes with jvm 1.5.0 which can be found in <6.5.0 install dir>/_jvm.
When you install 6.5.0 Service Pack1, it will use the jvm from SDP 6.5.0.
Note: 6.5.0SP1 is not a fresh install.  It can only be installed on top of 6.5.0 baseline.
Hope that helps.
Natalia
