Re: No Momentics uninstall
02/19/2008 8:00 AM
post5109
Ahhh ... thank you very much. I knew it was something small and "not too straightforward" that was keeping me from
installing this.
Yes, I have both Sun java 1.5 (sun-java5) and 1.6 (sun-java6) installed on my system. Before I try reinstalling I'll
double check to ensure that the root user has all the appropriate classpath junk.
Again, thanks for the help, it is much appreciated.
02/19/2008 8:26 AM
post5112
hmm ... here comes the next odd part ... I didn't find any vpd.properties under my /root directory (root's home), so I
did a "find / *|grep vpd" and it only came up with two unrelated man pages, /usr/bin/vpddecode and /usr/share/man/man8/
vpddecode.8.gz
so I removed a bunch of hidden folders (that I knew were unneccesary) and still no avail.
so if vpd.properties is not present anywhere on the system, and I've removed /opt/qnx632 as well as /etc/qnx , what else
could be preventing the installer from runing correctly?
Additionally, the momentics-6.3.2-xxxxxxxxxxxx-linux.bin will not run, even though it is a *.bin and it does have a+x in
its permissions, so I was using java -jar qnx_linux_setup.jar to run the setup. I hope this sheds some light on the
issue. Again, thanks Andy for your help, and thanks in advance for more help.
