04/26/2012 9:41 AM
post92745
In case mentioned below, correct form is:
#include "sys/csm.h"
OR
#include <sys/csm.h>
BUT NOT
#include "full/path/to/csm.h"
When you use "" gcc first looks at the directory where current file
(containing the inclue directive) is, so quoted form would be
appropriate for another header living in 'sys', and less correct, but
with little practical difference, would be using quoted include in your
.c file).
Stage headers:
If your header is in stage/usr/include, then this is added automatically
providing you correctly setup your environment. Observing compilation
line would reveal whether your stage/usr/include is added as one of
-I.... options.
Further, in case of stage, you do not need to use EXTRA_INCVPATH as it
should get added automatically.
Aleksandar
On 12-04-26 09:27 AM, Brandon Doherty wrote:
> I'm new to momentics, but I got mine working either with either the full path in "" or adding the include base path in
the project properties and using<> with the rest of the path
> ex
> extra include path [path to stage]/stage/usr/include
> #include<sys/csm.h>
> since csm.h is in stage/usr/include/sys
> Hope that helps.
> http://community.qnx.com/sf/go/post92744
