Re: RE: What is it called????
01/28/2008 8:55 AM
post4619
Thanks, Peter.
> 'use xxxx' tool.
> e.g.#> use slogger
Yeah, I'm hip to "use". The problem is that if I don't know what the function is called, I can't get help.
I'm accustomed to "man -k" as a starting point, but use doesn't seem to have that capability, as far as I've determined
>> I go to the QNX console and kill sshd and restart it >> and the client program
>> (putty.exe, run from Windows XP) and it works fine.
> [Peter] Network time out?
I could understand the client server connection timing out. I assume if it was really important to keep a process
running come hell or high water, I just nohup it so it can run as a terminal free daemon. That's fine.
My problem is, however, I want to be able to reconnect to a remote system using an SSH client program, but since the ssh
daemon seems to have just died, I can't reconnect to it without using the system console. I very likely will not have
access to the system console, and so this problem ends up being a checkmate.
I looked at sloginfo and got this, which hopefully someone out there can understand. Sadly, I don't!
Jan 25 17:09:00 1 8 0 Unable to read TTF file.
Jan 25 17:16:20 1 8 0 blkcache fseek failed
Jan 25 17:16:20 1 8 0 Unable to read TTF file.
Jan 28 07:10:18 5 21 0 run fault pid 761899 tid 1 signal 10 code 3 ip 0x8069420 opt/sbin/sshd
Jan 28 07:11:13 5 21 0 run fault pid 782379 tid 1 signal 4 code 1 ip 0x8069420 opt/sbin/sshd
Jan 28 07:17:27 1 8 0 blkcache fseek failed
Jan 28 07:17:27 1 8 0 Unable to read TTF file.
Jan 28 07:17:28 1 8 0 blkcache fseek failed
Jan 28 07:17:28 1 8 0 Unable to read TTF file.
Jan 28 07:17:43 1 8 0 blkcache fseek failed
Jan 28 07:17:43 1 8 0 Unable to read TTF file.
Jan 28 07:28:06 5 21 0 run fault pid 1179694 tid 1 signal 4 code 1 ip 0x8069420 opt/sbin/sshd
Jan 28 08:31:41 2 8 0 Render cmd 0x45 failed
Note the boundary between the 25th and the 28th... That was the weekend, at the end of which sshd has stopped working.
Like I said, just killing smbd from a neutrino terminal and restarting it gets the process rolling again. But I wan't be
able to do that in practice.
Thanks - Frank
