Debugging a running process...
01/11/2008 3:52 PM
post4247
How does one go about connecting to a running process to debug it?
RE: Debugging a running process...
01/11/2008 3:55 PM
post4248
Debug configurations->C/C++ Qnx Attach to Process w/Qconn (IP)
From: Frank Rudolph [mailto:rudolph@beaconpower.com]
Sent: January 11, 2008 3:53 PM
To: momenticsgs-community
Subject: Debugging a running process...
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post4247
Re: RE: Debugging a running process...
01/11/2008 4:12 PM
post4252
Hate to be a dunce, but where do I find "Debug Configurations"?
- Frank
RE: RE: Debugging a running process...
01/11/2008 4:20 PM
post4254
Launch configurations dialog. In my version Run->Open Debug Dialog...
Are you sure it is not mentioned in Help documentation anywhere?
Re: RE: RE: Debugging a running process...
01/11/2008 4:39 PM
post4256
AHA! There's no "RUN" menu item on my main menu toolbar.
I thought there was one previously, but not now. I've check all the perspectives... same story.
- Frank
RE: RE: RE: Debugging a running process...
01/11/2008 4:46 PM
post4257
I have IDE 4.5. If you have 4.0.1 it may be called differently (eclipse guys
renamed it), but it is same dialog where run/debug configurations. How to
you normally edit debug configuration???
Try right click Debug As...-> Open Debug Dialog... or soothing like this.
Sent: January 11, 2008 4:40 PM
Subject: Re: RE: RE: Debugging a running process...
- Frank
http://community.qnx.com/sf/go/post4256
01/12/2008 12:12 PM
post4260
Perspectives can be configured with different commands, which in turn will
populate the toolbar
and menu bar content. Generally they try and include the commands which are
most relevant
to the main activity of the perspective, but sometimes that isn't what you
as an end user may
want (sometimes more, sometimes less).
For any given perspective you can customize it:
Window > Customize Perspective ...
and select the items which are most relevant to you. Unfortunately, other
than editiing the
plugin, there is no easy way to spread a command across all possible
perspectives .. though
you can create your own perspective that has all the stuff you commonly use.
You might want to take a look through the debugging chapter in the IDE help
documentation
since it covers several of your questions (like how to attach to a running
process) and includes
pictures to help.
Help > Help Contents
Hope this helps ... and keep asking the good questions, others out there
benefit from the
discussion I'm sure.
Thomas
01/14/2008 6:14 PM
post4288
That's all fine and good. But
1. I couldn't find anything in un der Customize Perpectives that allowed
you to change the words at the top of the main menubar.
2. Today when I came in and tried the same experiments with this
platform, the main menubar read:
"File Edit Navigate Search Project Run Window Help"
Yesterday it read:
"File Edit Navigate Search Project Log Window Help"
Under Log, yesterday, it had all the things that today are under Run.
Doesn't that seem a little weird to you?
- Frank
Sent: Saturday, January 12, 2008 12:12 PM
will
are
most relevant
you
as an end user may
other
than editiing the
use.
help
documentation
running
pictures to help.
benefit from the
Thomas
http://community.qnx.com/sf/go/post4260
01/14/2008 7:20 PM
post4291
> Yesterday it read:
Yes ... though I have seen the same thing myself when I was running a remote
VNC connection. I think that it has to do with the fact that there is a Log
menu
contribution that provides content into the Run menu items, and a race
condition
on 'who contributes to the menu first' ... at least my current theory,
though I haven't
seen the problem again to come up with a reproducible case for a bug report.
So if you are seeing it repeatedly, lets get a bug report in with your
environment
and see what can be done to fix what is certainly a confusing problem.
Thomas
01/15/2008 8:31 AM
post4303
Based on my experience with Wind River, I was wondering when the subject
of log files would come up. Every time I contacted them about a problem
they would tell me to send them the error log file and file a TSR report
to track the problem. Are there similar tools QNX routinely uses to
track down a bug?
- Frank
Sent: Monday, January 14, 2008 7:21 PM
allowed
> Yesterday it read:
remote
Log
menu
condition
though I haven't
report.
environment
Thomas
http://community.qnx.com/sf/go/post4291
01/15/2008 9:09 AM
post4305
> track down a bug?
> - Frank
Would we be a software company if we didn't have a bug tracking system =;-)
If you have priority support, then you should work with your priority
support
technical account manager (TAM) to get the issue addressed and a patch
issued if required. If you only have standard support, then you can report
the issue, and a problem report will be filed on your behalf. The standard
information should be gathered in both cases: host/target environments and
software versions, any log files or core dumps etc.
It is on the community roadmap to open up the bug tracking system, but the
integration is deeply embedded into many other systems which is why it
hasn't been part of the initial community roll-out.
Working with developers through these forums is also great, but for issues
that are more than simply 'how do I get to A from B" and are true bugs,
we should make sure that they get recorded and tracked officially.
Thomas ... who is currently on leave from QNX
01/15/2008 12:32 PM
post4321
What is the difference between "Standard support" and "priority
support"?
If I pay (approx) $1800 per year for support, which is this?
- Frank
Sent: Tuesday, January 15, 2008 9:10 AM
subject
problem
report
> track down a bug?
> - Frank
support
report
standard
and
the
issues
http://community.qnx.com/sf/go/post4305
01/15/2008 12:57 PM
post4325
Call qnx support line, or write mail to standard@qnx.com
They should be able to clarify it for you. Also it you have support plan it
might be faster to talk to them directly rather than in the open forum.
01/15/2008 10:46 AM
post4310
Let me clarify what you have done and what is not working.
You have sources and binaries mounted using samba on host machine.
You compile on target machine, and this is a same as "debugging" target.
In this case the following scenario should work:
- Create standard make project
- Inside a project create a linked resource pointing to mounted directory
(Or create a project in "non standard" location pointing to mounted
directory)
- After every re-build of source hit Refresh on the project
To debug:
- Create QNX Qconn (IP) launch configuration
- Select executable in main tab pointing to host executable
- Select run executable on target in Download tab and select executable on
target
- In source tab Add..->Path Mapping->Ok. Click Edit... on Path Mapping and
add path mapping between host and target source path
- Launch debugger
01/15/2008 12:29 PM
post4320
I need a little more specifics...
How do I "create a linked resource pointing to mounted directory"
How do I " create a project in "non standard" location pointing to
mounted
Directory"
What I have done instead is to just import the source code and the
binary executable. This seems to work, but as for automatic
synchronization between the resource and the host resident source code,
I have had to use a source compare utility to synchronize them.
Thanks again
- Frank
Sent: Tuesday, January 15, 2008 10:47 AM
Subject: RE: RE: RE: Debugging a running process...
directory
directory)
To debug:
on
target
and
- Launch debugger
http://community.qnx.com/sf/go/post4310
01/15/2008 12:51 PM
post4324
I still need to know the version of IDE you are using, because steps are
different.
To create a link folder
Right click on Project -> New -> Folder
Click Advanced>>
Select Link to folder in file system
Browse...
To create project in non standard location (it must be read-write in this
case)
Pick a wizard for new project creation for standard make project (steps are
different for different version)
In first page of wizard uncheck "Use default location"
Navigate to mounted directory that contain root of project and select it
01/11/2008 4:31 PM
post4255
Just checked user doc on it for IDE. It does not describe debug Attach...
Sorry about that, I will submit a pr.
Re: Debugging a running process...
01/11/2008 3:56 PM
post4249
localhost:/home/seanb >cat &
[1] 974900
localhost:/home/seanb >gdb /bin/cat 974900
GNU gdb 5.2.1qnx-nto
Copyright 2002 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "ntox86"...(no debugging symbols found)...
Attaching to program `/bin/cat', process 974900
Reading symbols from /home/seanb/svn/stage/x86/lib/libc.so.2...done.
Loaded symbols for /home/seanb/svn/stage/x86/lib/libc.so.2
[Switching to process 974900]
0xb0331833 in MsgSend () from /home/seanb/svn/stage/x86/lib/libc.so.2
(gdb) bt
#0 0xb0331833 in MsgSend () from
#1 0xb03178bd in read () from /home/seanb/svn/stage/x86/lib/libc.so.2
#2 0x080486ba in _btext ()
#3 0x08048914 in main ()
(gdb)
01/11/2008 4:11 PM
post4250
Thank you.
Although I was actually wondering how to do it from the IDE, this will be useful too!
- Frank
01/11/2008 4:12 PM
post4251
Look at the 'attach' command in gdb.
All that 'attach' needs is the pid of the running process. For a local
process, that's all you need.
If you are debugging on a remote system, then 'pdebug' needs to run on
the remote system, and gdb needs to connect to pdebug before you run
gdb's 'attach' ('target qnx <target_ip_addr> <pdebug_tcp_port>' command
in gdb).
Of course, all of this is done automagically if you use the IDE with
qconn.
But if you are a minimalist, you can just run gdb+pdebug from the
command line.
02/26/2008 11:10 AM
post5277
OK ... Time-out. Can we get back to the original question?
How do I attach to a remote process using the latest Momentics 4.0.1? I see "C/C++ QNX Attach to a Process w/QConn" in
the DEbug Configuration but I don't understand the steps required setup a configuration and actually attach to a process
Can some one please be specific?
02/26/2008 11:14 AM
post5278
Create a configuration under C/C++ QNX Attach to a Process w/Qconn
- select a binary matching running process
- select a project
- select a target
Run process on a target (or it is already running)
Select this configuration from Run->Debug... and click Debug button
Window with process list would pop up
Select a process that you want to attach
Debugger would start in IDE
