How to create a "project container" in IDE v.4.6?
10/27/2010 4:52 PM
post72720
I want to group several projects together in the Projects Explorer,
but can't figure how to do this in IDE v.4.6.
In Visual C++ we can create "solution folder"
containing several projects, for example
App1
Libs
lib1
lib2
Tests
test1
test2
"Libs" and "Tests" are folders.
Is this possible in Eclipse?
Also, when I create a new QNX project, it suggests the default location
in the workspace root. I want to place the new project in sub-folder,
but then the IDE prompts for the full path. It does not seem to allow
select location relative to the workspace?
Where the IDE stores paths of projects?
Thanks for any idea,
- S
Re: How to create a "project container" in IDE v.4.6?
10/27/2010 5:05 PM
post72723
Groupping you can do using Working Sets. Project Explorer view menu -> Configure Working Sets...
Then you switch to show working sets instead of project on top level.
I am not sure what are talking about selection relative to workspace - it has to be full path, but it can be anywhere in
workspace (I think...)
> App1
> Libs
> lib1
> lib2
> Tests
> test1
> test2
> - S
> http://community.qnx.com/sf/go/post72720
RE: How to create a "project container" in IDE v.4.6?
10/27/2010 5:18 PM
post72726
Use "working set" to group project. See this Eclipse help page for
working set:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse.platform.doc
.user/concepts/cworkset.htm
The new project wizard is common for all Eclipse project, not QNX
project specific. If you create a simple Eclipse project its location is
also default to the workspace root. The "Browse..." button does not use
workspace resource but file system resource that's why you need to use
the full path.
IDE store paths to projects in the workspace metadata. You don't want to
manipulate the metadata manually.
Sent: Wednesday, October 27, 2010 4:53 PM
To: momenticsgs-community
Subject: How to create a "project container" in IDE v.4.6?
App1
Libs
lib1
lib2
Tests
test1
test2
- S
Re: RE: How to create a "project container" in IDE v.4.6?
10/27/2010 8:01 PM
post72733
Thank you, Andy.
The working set feature is useful, albeit not quite what I wanted.
About absolute paths: I need all paths in the workspace be relative to the workspace root. Otherwice the project cannot
be copied to other machine where the path to workspace is different. How people cope with this issue?
My apologes for n00b questions, it is my first project with the QNX IDE.
- S.
RE: RE: How to create a "project container" in IDE v.4.6?
10/27/2010 8:31 PM
post72734
You don't want to copy the projects from their file system because there are project metadata you won't be able to copy.
If you need to transfer projects you can "export" them to an archive file, transfer the archive file to another machine
, and "import" them to another workspace. The "export" and "import" will handle the path conversion.
Sent: Wed 27/10/2010 8:01 PM
Subject: Re: RE: How to create a "project container" in IDE v.4.6?
Thank you, Andy.
- S.
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post72733
10/28/2010 7:25 AM
post72762
You cannot share "workspace/.metadata" folder, you can only shared
projects itself. We use source control for that, you can
check in project with .project file, and later other developer can check
it out from eclipse and project will be created automatically.
To check out few projects at the same time we use feature called
"project team set". What version control you are using?
Btw what is wrong with working sets for grouping?
On 27/10/2010 8:01 PM, Saul A wrote:
> Thank you, Andy.
cannot be copied to other machine where the path to workspace is different. How people cope with this issue?
> Regards,
> - S.
10/29/2010 11:29 PM
post73071
Working sets do not look and work like subfolders in Visual Studio solution.
On the other hand, in VS you cannot select a subfolder and build it.
Need just to get used to Eclipse...
We currently use subversion (latest Tortoise); planning to move to git or mercurial.
From the links below, it seems that backing up the Eclipse metadata and absolute paths are common problems:
http://stackoverflow.com/questions/1366953/which-eclipse-project-workspace-files-should-be-added-to-source-control
http://stackoverflow.com/questions/717247/how-to-transfer-eclipse-workspace-and-project-from-windows-to-linux-and-mac
http://stackoverflow.com/questions/950476/how-to-recover-corrupted-eclipse-workspace
I've found that the absolute paths are saved in common.mk.
Replaced them to relative, using the Eclipse(?) macros; it works
and seems to survive editing project properties.
Then, it may be indeed easier just to recreate the workspace and
re-import all projects, as the valuable data is contained
only in QNX makefiles and .project & .cproject ?
S.
10/30/2010 7:40 AM
post73073
A trial-and-true practice is never copy the whole workspace. Not only the machine specific settings (like path) are not
share-able, but also the workspace metadata is not warranted to be identical in between different version of IDEs.
As you said in your last sentence, the project data can be shared. The "export" and "import" functions ensure project
data is preserved and that's exactly what you need.
Why not check-in your projects to ease the multi-site, multi-user development?
Sent: Fri 29/10/2010 11:29 PM
Subject: Re: How to create a "project container" in IDE v.4.6?
S.
10/31/2010 8:30 PM
post73108
Thanks, this is exactly what I did: checked in the Eclipse .project, .cproject files, and all QNX .mk and Makefiles in
all subdirs of all projects.
Changed all absolute paths in .mk files to macros and env. variables.
Now, the hard part - explain to the customer how to recreate the workspace :)
- S.
