Forum Topic - Debug as QNX C/C++ Application throws java.lang.NullPointerException:
I am getting the above error when I try to debug my application.  Guys, please help me. I am in a urgent need.
Thanks in advance.
Vishal
Re: Debug as QNX C/C++ Application throws java.lang.NullPointerException
What version of SDP are you using? Which IDE version?
On Mon, 2010-10-04 at 07:46 -0400, Vishal Agrawal wrote:
> Thanks in advance.
> Vishal
> http://community.qnx.com/sf/go/post69397
i am using the 6.5 version. i get this error when i actually try to debug my application after the config.
there is no log file in the .metadata directory.
Should be .log
Where is your binary? Is it actually in the project or it is link or something like that?
Try to create launch configuration yourself (instead of Debug As...) - and make sure there is no errors displayed.
> http://community.qnx.com/sf/go/post69421
yeah, my binary is linked. i did the launch configuration myself. there was no error. after the configuration when i try
 to run i am getting this error.
Probably does not work on linked resources. Can you link the folder where the binary is instead?
try to run i am getting this error.
> http://community.qnx.com/sf/go/post69426
- What kind of application is your project? Can you "export" your
project and attach to this thread?
- When did you get the NPE? Did it happen when you first open your debug
launch config, or when you actually launch your program?
- Can you attach your workspace log file? You can find the log file
under your <workspace_dir>/.metadata/.log
Reply-to: post69397@community.qnx.com
To: momenticsgs-community <post69397@community.qnx.com>
Subject: Debug as QNX C/C++ Application throws
Date: Mon, 4 Oct 2010 07:46:18 -0400 (EDT)
Thanks in advance.
Vishal
QNX Momentics Getting Started
Log file is attached.
Attachment: Text log 2.46 KB
It does not work because it is a link
On 05/10/10 12:41 AM, Vishal Agrawal wrote:
> http://community.qnx.com/sf/go/post69529
But it is working in older version of momentics. I don't know why it is not working in newer version.
Vishal
Exception says it cannot validate path for the binary. Does you launch configuration has project set?
> Vishal
> http://community.qnx.com/sf/go/post69547
What do you mean by "launch configuration has project set?" I didn't get you.
Vishal Agrawal
I think my problem is due to qnx650 tool chain.
Because I got the same error with Momentics 6.4.1 + QNX650 tool chain
Can somebody look into this.
Vishal Agrawal
I already answered: you cannot use linked file as binary
> Thanks
> Vishal Agrawal
> http://community.qnx.com/sf/go/post70386
