RE: Problems on install QNX Neutrino RTOS on to i386
10/24/2007 2:22 PM
post2279
This looks like a driver problem...
Try to post it in OS/BSP forums.
Sent: October 24, 2007 12:43 PM
To: momenticsgs-community
Subject: Re: Problems on install QNX Neutrino RTOS on to i386
Hi, Sada:
Thanks a lot for your replying!
Frankly, I do not wait for a long time at first. Maybe after several
minutes I reboot it and it stoped or dead at following display:
Dectected USB scanning for devices
Trying SATA mvSata. Scanning for devices......
Then I think I left the PC on for more than one day and still dead.
According to your experience, I will try to re install the OS and wait
for another day to see the result with patience.
Best wishes,
George
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post2274
10/24/2007 2:46 PM
post2280
A couple of things to try...
1) Hit ESC for .altboot. This will use the non DMA image.
2) If that allows you to boot, you can rebuild the QNX image file.
cd /usr/qnx632/target/qnx6/x86/boot build
edit qnxbasedma.build and find the following:
[data=copy]
seedres
pci-bios
devb-eide
devb-amd
devb-aha2
devb-aha4
devb-aha7
devb-aha8
devb-adpu320
devb-ncr8
devb-umass
devb-ahci
devb-mvSata
umass-enum
umass-enum.cfg
io-usb
io-hid
Change it so that it looks as follows:
[data=copy]
seedres
pci-bios
devb-eide
devb-umass
umass-enum
umass-enum.cfg
io-usb
io-hid
Save the file and rebuild the image in the following manner:
mkifs -vv qnxbasedma.build /.boot
See if that changes the behaviour. At bootup, you should get an error saying
spawn of devb-mvSata failed rather than the build hanging.
If that doesn't work, can you please provide as full a description as
possible of your hardware?
Cheers,
-Brian
> From: Zhihong Ke [mailto:zhke@sympatico.ca]
> Sent: Wednesday, October 24, 2007 12 43
> Hi, Sada:
> after several minutes I reboot it and it stoped or dead at
> following display:
> the OS and wait for another day to see the result with patience.
> Best wishes,
> George
