Re: Installation error on non-supported Linux
09/19/2007 4:27 PM
post1434
> Okay, I don't think you should have to do this, but try the following:
> Create an directory in /tmp call 632install. Copy the complete contents from
> the ISO to this directory. Run the bin file from here.
Don't have enough space in /tmp, so I copied all of it to another partition.
Installed fine from there. I should have thought of that. Brain is stuck in
low gear.
> I was getting the same error on Ubuntu as you when I tried to run the install
> with just a java -cp /media/cdrom/qnx_linux_setup.jar run. I don't think it
> could find my java installation at that point. Running the bin from the CD
> ran in to the Ubuntu permission thing with CD's, so I copied the CD to the tmp
> dir I created and it installed fine. Make sure you are also running that bin
> file with root permissions.
On my system I have Java in a non-standard location. Still installed okay.
> Maybe because you are mounting the ISO, it is screwing up the bin file
> extraction.
I think this is the case. Perhaps there is a mount option that is needed, not sure.
It is odd because you would imagine that mounted either as a CD or loop would
amount to the same thing.
Perhaps for other users reference someone could put a note in the installation
documentation about this.
Also, seems to work on Mandriva 2007.1 Spring. Have to make some tests to be
sure. Momentics menu is there also (under KDE, don't have GNOME installed).
Might be an idea to try it with IcedTea Java (an OpenJDK version). I have used
it with Eclipse and it works up to a point. Eventually it crashes, but that might
be because I installed an unstable version.
Thanks for the assistance.
Raymond
