Forum Topic - malloc causes segfault/SIGSEGV: (13 Items)
I'm using C++ in QNX 6.3.2 and I got a segmentation fault while I was calling "put" on a ostream. The ostream,
internally called malloc and it cause the segfault.
Here is the backtrace from the core file:
(gdb) bt
#0  0xb031ee55 in _block_mem_malloc_align () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#1  0xb031ef6d in _band_get_aligned () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#2  0xb031f01b in _band_get () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#3  0xb03210ec in __malloc_lock () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#4  0xb03211c8 in __malloc () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#5  0xb031ea72 in malloc () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#6  0xb851abef in __builtin_new () from /usr/qnx632/target/qnx6/x86/lib/libcpp.so.3
#7  0xb851a9f3 in __builtin_vec_new () from /usr/qnx632/target/qnx6/x86/lib/libcpp.so.3
#8  0x080556a3 in stringbuf::overflow (this=0x7e5bf04, c=0) at /opt/qnx632/target/qnx6/usr/include/g++-3/sstream:110
#9  0xb823951d in __overflow () at ../../../../libstdc++/std/std_valarray.h:268
#10 0xb823dbdc in _IO_putc () at ../../../../libstdc++/std/std_valarray.h:268
#11 0xb8253d30 in ostream::put (this=0x7e5bf00, c=0) at ../../../../libio/streambuf.h:395
#12 0x0806a8a3 in operator<< (os=@0x7e5bf00, tag=@0x809f570) at rftag-analog.cc:44
#13 0x080636e9 in operator<< (os=@0x7e5bf00, grp=@0x80c79b8) at ielgroup.cc:321
#14 0x0806e0b9 in IElcomConnection::handlePeriodicGroup (this=0x80be0a0) at ielcomconnection.cc:558
#15 0x0806de6a in IElcomConnection::thread_handlePeriodicGroup (arg=0x80be0a0) at ielcomconnection.cc:524
Until #12 is what my program does, after that all is inside the call to "put" of the ostream (os is a ostream).
From the back trace it seems clear that what is causing the segfault is inside the malloc, so it should be a bug in
QNX's libc, if I'm not missing something.
Just in case it matters, besides Apache, php, ssh and RealFlex (with Ls900 driver) its a plain/default QNX 6.3.2 run-
time installation on x86. And this program (the one I pasted the back trace) is multi-thread, and this is the thread it
causes the segfault.
Also, I don't know how to reproduce it, it happened only once in almost 8 months.
Does this happen to anyone (segfault in malloc) ? It's a known bug or can I report it somewhere else ? Does anyone know
if 6.3 is maintained yet and I can expect a new release fixing this ?
Thanks a lot,
Rodrigo
RE: malloc causes segfault/SIGSEGV
Seg faults in libc's malloc or free routines are generally caused by the
application program overwriting areas of heap that it's not supposed to,
not by libc itself. To manage the heap, libc may maintain its own
internal data structures close to allocated memory, or in areas of
previously allocated memory that have been freed. If the application
program writes past the bounds of memory it has allocated, or writes
into dynamic memory it has already freed, the type of seg fault you are
seeing can result.
I suggest using a heap analysis tool to try and find out why the memory
corruption is occuring. Examples are the IDE memory analysis, and the
open source dmalloc library.
Max
From: Rodrigo Campos [mailto:community-noreply@qnx.com]
Sent: Monday, August 24, 2009 12:16 PM
To: momentics-community
Subject: malloc causes segfault/SIGSEGV
(gdb) bt
rftag-analog.cc:44
ielgroup.cc:321
8 months.
Thanks a lot,
Rodrigo
http://community.qnx.com/sf/go/post36540
Re: RE: malloc causes segfault/SIGSEGV
> not by libc itself.
In this case it is most probably cause by a bug in the C++ library and streams.  This bug shows up when using multi-
thread.  I was told this bug would not get fixed.  You need to upgrade to 6.4.X.
> (gdb) bt
> rftag-analog.cc:44
> ielgroup.cc:321
> 8 months.
> Thanks a lot,
> Rodrigo
Re: malloc causes segfault/SIGSEGV
>> not by libc itself.
You report was against using Dinkumware C++ Library and Rodrigo is using
the GNU C++ library. Separate libraries, separate issues.
Ryan Mansfield
>> -----Original Message-----
>> (gdb) bt
>> rftag-analog.cc:44
>> ielgroup.cc:321
>> 8 months.
>> Thanks a lot,
> >> not by libc itself.
> streams.  This bug shows up when using multi-thread.  I was told this bug
I was using the standard C++ library for QNX, if I'm not wrong. Do you recommend to use an other C++ library in QNX 6.3.
2 ?
Thanks a lot,
Rodrigo
>>>> not by libc itself.
3.2 ?
The default depends on the compiler driver you're using. If you use qcc
the default C++ library, is Dinkum C++ library. If you are using the gcc
driver, the default C++ library is the GNU C++ library.
I recommend only using one C++ library and not mixing the two. I just
noticed the backtrace you pasted shows your using both libstdc++.so.5
and libcpp.so.3 which could be problematic.
Ryan Mansfield
> >>>> not by libc itself.
> recommend to use an other C++ library in QNX 6.3.2 ?
Ahhh
Yes, I've just noted it too =)
The one that is loading libcpp is one library from RealFlex that is also loading the libstdc++:
ldd /opt/rf6/lib/libauth.so
/opt/rf6/lib/libauth.so:
	libauth.so => /opt/rf6/lib/libauth.so (0xb8200000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb820d000)
	librfio.so => /opt/rf6/lib/librfio.so (0xb8277000)
	libsocket.so.2 => /lib/libsocket.so.2 (0xb8281000)
	libm.so.2 => /lib/libm.so.2 (0xb82a5000)
	libcpp.so.3 => /lib/libcpp.so.3 (0xb82c1000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb8335000)
	libstdc++.so.2.2.10.0 => /lib/libstdc++.so.2.2.10.0 (0xb8340000)
Thanks a lot for your response, I will report the bug to Real Flex as their library is linking with the two libraries
and it is problematic (and I will let them know you suggest to use the GNU C++ library).
What I don't fully understand is which code is run every time I call a function from the stl ? does it depend on the
order the two libraries were loaded ? There is no problem if both libraries define the same symbols ? could both be
loaded at the same time ?
Thanks a lot,
Rodrigo
RE: RE: malloc causes segfault/SIGSEGV
There are multiple bugs in 6.3.2 that can collide when using 6.3.2
Dinkum ostreams.
1) name_detach() leaks a sync object (mutex???) into the heap.
2) ostream << mallocs memory for a mutex, registers the mutex with the
kernel, but does not check the error return of the registration.
If that malloced memory contains one of those leaked sync objects the
registration fails and the ostream mutex is not initialized. The result
is either no thread-safe coordination, or the ostream thread remains
blocked forever on a bogus mutex that will never unblock. I don't know
whether this can lead to a segment violation, but I would think that the
"no coordination" scenario could.
The name_detach() bug has been fixed in 6.4. I was told that the ostream
non-check for an error return would not be fixed, so I assume it is
still there in 6.4.1.
Mario, are there additional streams bugs that you are aware of?
> From: Mario Charest [mailto:community-noreply@qnx.com]
> Sent: Monday, August 24, 2009 12:37 PM
> Subject: Re: RE: malloc causes segfault/SIGSEGV
> the
> to,
> > not by libc itself.
was
> > (gdb) bt
> > rftag-analog.cc:44
> > ielgroup.cc:321
> (this=0x80be0a0)
> > Until #12 is what my program does, after that all is inside...
> From: Martin Doane [mailto:community-noreply@qnx.com]
> Sent: Monday, August 24, 2009 1:32 PM
> Subject: RE: RE: malloc causes segfault/SIGSEGV
> Dinkum ostreams.
> the
> ostream
I do not have any details, sorry.  All I know is that on multi-core and more than 2 threads doing operation it crashed
almost instantly on 6.3.2 and doesn't on 6.4.X
> by
> > the
> supposed
> > to,
> > > not by libc itself.
> and
> was
> > > (gdb) bt
Re: RE: RE: malloc causes segfault/SIGSEGV
> Dinkum ostreams.
II'm not using Dinkum ostreams, if I'm not wrong. Or that's the name of standard QNX's libc and I'm using it ? :)
Thanks a lot anyways,
Rodrigo
RE: RE: RE: malloc causes segfault/SIGSEGV
The Dinkum library is libcpp. The GNU library is libc++.
> Sent: Monday, August 24, 2009 2:09 PM
> Subject: Re: RE: RE: malloc causes segfault/SIGSEGV
> > Dinkum ostreams.
of
> Rodrigo
> http://community.qnx.com/sf/go/post36560
Re: RE: RE: RE: malloc causes segfault/SIGSEGV
So you say I'm using Dinkum because the backtrace says:
(note libcpp) ?
It's installed by default Dinkium C++ library ? II will investigate about it
Also, it seems I'm using GNU C++, since the output of ldd is:
# ldd ielcom-rf
./ielcom-rf:
	libscanner.so => /opt/rf6/lib/libscanner.so (0xb8200000)
	libstdc++.so.2.2.10.0 => /lib/libstdc++.so.2.2.10.0 (0xb821b000)
	libm.so.2 => /lib/libm.so.2 (0xb8269000)
	libsocket.so.2 => /lib/libsocket.so.2 (0xb8285000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb82a9000)
	librfio.so => /opt/rf6/lib/librfio.so (0xb8313000)
	libauth.so => /opt/rf6/lib/libauth.so (0xb831d000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb832a000)
	libph.so.3 => /usr/lib/libph.so.3 (0xb8335000)
	libphexlib.so.3 => /usr/lib/libphexlib.so.3 (0xb8435000)
	librftrans.so => /opt/rf6/lib/librftrans.so (0xb8460000)
	libflex.so => /opt/rf6/lib/libflex.so (0xb846c000)
(note libstdc++, most of other libraries are from RealFlex)
But ldd /opt/rf6/lib/libauth.so shows:
(note, libcpp)
But I'm not sure if libcpp is Dinkum C++ library, I will see that now. But if it is and both are loaded at the same time
, I don't which one it's being called.
Thanks a lot,
Rodrigo
> seeing can result.
I'm not calling malloc, I'm just calling "put" in a ostream. The malloc is all done inside that call to "put" of a
ostream, so if its writing past the bounds, it should be a bug en QNX's libc, if I'm not wrong.
Perhaps (but it sounds very rare) the stack/heap is corrupted and that causes it. But it seems very rare, since that
code is run all the time, and never fails/crash (just this time)
I will see if I can create a test case, but as it happen once in 8 months, I don't think it would be difficult to
reproduce.
Rodrigo
