Forum Topic - problem with clock_settime() function on QNX 6.4.0: (17 Items)
hi,
I am migrating our application from QNX 630 to QNX 6.4.0 on PPC 8270 target.
I am facing issues with clocksettime() function to set the system clock.
The input parameter to that function is the address of a  time spec structure.
The values passed to tv_sec,tv_nsec are fine.
But unable to set the system clock as per the values.
In the QNX release notes its noted that if tv_nsec > 100 million the function will return an error EINVAL.
The function is not returning any error still its not setting the system time.
Do i need to set any proccessor plag for the function to work??
Is there any limitation on "tv_sec " value also??
I have taken care that the time should not cross "year 2038"
thwn why the function does not work???
Re: problem with clock_settime() function on QNX 6.4.0
is there any delay setting the system clock time???on QNX 6.4.0?? on ppc target??
After setting the system time by clock_settime() function
if i give sytem("date"); command its able to show the updated time.
What could be the reason.?
Can you post an example of the code you are using?
soujanya Yelchuri wrote:
> hi,
> http://community.qnx.com/sf/go/post36153
cburgess@qnx.com
RE: problem with clock_settime() function on QNX 6.4.0
	stime.tv_nsec = 0;
	stime.tv_sec += (60*60)*24L;  /* Add one day */
	// Set the time
	if( clock_settime(CLOCK_REALTIME,&stime) == -1 )
		perror( "could not setclock" );
From: Colin Burgess [mailto:community-noreply@qnx.com]
Sent: Wednesday, August 19, 2009 8:32 PM
To: momentics-community
Subject: Re: problem with clock_settime() function on QNX 6.4.0
> hi,
cburgess@qnx.com
http://community.qnx.com/sf/go/post36269
Ok, so to clarify
this worked on 6.3.0
it doesn't set the system clock on 6.4.0
does the date utility work (to set the clock?) - it uses clock_settime too.
Colin
> 	stime.tv_nsec = 0;
> 	// Set the time
>> hi,
cburgess@qnx.com
No if u use date -s no.sec at that time its diplaying correctly but afterwards it shows the old time..
Soujanya Yelchuri
Sent: Wednesday, August 19, 2009 8:42 PM
Ok, so to clarify
Colin
> 	stime.tv_nsec = 0;
> 	// Set the time
>> hi,
cburgess@qnx.com
http://community.qnx.com/sf/go/post36275
date -s no.sec doesn't set the date, it just turns the seconds into a date string.
> Regards,
> Soujanya Yelchuri
> Ok, so to clarify
> Colin
>> 	stime.tv_nsec = 0;
>> 	// Set the time
>> -----Original Message-----
>>> hi,
cburgess@qnx.com
If I give
	stime.tv_nsec = 0;
	// Set the time
	System("date");
Then its able to show the latest date.
If I remove System("date"); then its unable to set the new time.
Soujanya Yelchuri
Ok, so to clarify
Colin
> 	stime.tv_nsec = 0;
> 	// Set the time
>> hi,
cburgess@qnx.com
If System("date") is showing the correct date/time then the system clock must have been set.
How are you determining that the date wasn't set correctly?
> If I give
> 	stime.tv_nsec = 0;
> 	// Set the time
> 	System("date");
> Regards,
> Soujanya Yelchuri
> Ok, so to clarify
> Colin
>> 	stime.tv_nsec = 0;
>> 	// Set the time
>>> hi,
cburgess@qnx.com
if i call system("date");
after some time around 5 mins at the end of my statup
its unable to show the time what i set..
what i mean to say is the clock_settime() function is unable to set the date and time.
if iam accessing the date immediately after setting date then its able to update the new time else no
thats my oservation..may be wrong..
Sent: Wednesday, August 19, 2009 8:53 PM
> If I give
>       stime.tv_nsec = 0;
>       // Set the time
>       System("date");
> Regards,
> Soujanya Yelchuri
> Ok, so to clarify
> Colin
>>      stime.tv_nsec = 0;
>>      // Set the time
>>> hi,
cburgess@qnx.com
http://community.qnx.com/sf/go/post36287
Are you sure that no other app is messing with the time - because reading the clock has no affect on the system time.
> From: Colin Burgess [community-noreply@qnx.com]
>> If I give
>>       stime.tv_nsec = 0;
>>       // Set the time
>>       System("date");
>> Regards,
>> Soujanya Yelchuri
>> Ok, so to clarify
>> Colin
>>>      stime.tv_nsec = 0;
>>>      // Set the time
>>>> hi,
i am sure that no other application is trying to write at the same time.
Sent: Wednesday, August 19, 2009 10:31 PM
>> If I give
>>       stime.tv_nsec = 0;
>>       // Set the time
>>       System("date");
>> Regards,
>> Soujanya Yelchuri
>> Ok, so to clarify
>> Colin
>>>      stime.tv_nsec = 0;
>>>      // Set the time
>>>> hi,
Maybe not at the same time.. but maybe later...
>>> If I give
>>>       stime.tv_nsec = 0;
>>>       // Set the time
>>>       System("date");
>>> Regards,
>>> Soujanya Yelchuri
>>> Ok, so to clarify
>>> Colin
>>>>      stime.tv_nsec = 0;
>>>>      // Set the time
>>>>> hi,
>>>>> But unable...
So basically, if I can get you to confirm...
clock_settime(CLOCK_REALTIME, &atime);
clock_gettime(CLOCK_REALTIME, &btime);
then btime makes sense (ie it reflects the update from atime, ie a date or so in the future)
whereas
... wait 5 mins ...
date
does NOT show the updated time?
>> If I give
>>       stime.tv_nsec = 0;
>>       // Set the time
>>       System("date");
>> Regards,
>> Soujanya Yelchuri
>> Ok, so to clarify
>> Colin
>>>      stime.tv_nsec = 0;
>>>      // Set the time
>>>> hi,
>>>> I have taken care that the time should not cross "year...
yes.
Sent: Wednesday, August 19, 2009 10:51 PM
whereas
... wait 5 mins ...
date
>> If I give
>>       stime.tv_nsec = 0;
>>       // Set the time
>>       System("date");
>> Regards,
>> Soujanya Yelchuri
>> Ok, so to clarify
>> Colin
>>>      stime.tv_nsec = 0;
>>>      // Set the time
>>>> hi,
>>>> The function is not returning any error still its not setting the system...
Ok, and what about
clock_settime()
while(1) {
	clock_gettime();
	if ( time has gone back ) {
		freakout();
	sleep(1);
because it sure sounds like someone is resetting the date back somehow.
> yes.
> whereas
> ... wait 5 mins ...
> date
>>> If I give
>>>       stime.tv_nsec = 0;
>>>       // Set the time
>>>       System("date");
>>> Regards,
>>> Soujanya Yelchuri
>>> Ok, so to clarify
>>> Colin
>>>>      stime.tv_nsec = 0;
>>>>      // Set the time
