Forum Topic - rmat file size limit: (14 Items)
It appears that the .rmat file generated by the memory analysis tool has a size limit of a signed long (2147483647).
After this limit is reached, I cannot export memory events any longer.  Are events or bin snapshots still captured when
the file has reached the limit?  Are older events removed from the file?  Or is the file size limit a bug?
My set up includes Momentics IDE 4.6 (Build id: I20090510), which I use with QNX 6.3.2a on my target.  I have a version
of qconn and librcheck.so that works with this IDE.
Please let me know if there is a fix for this issue.
Re: rmat file size limit
there is no fix for size limit but there is alternative way for
capturing data - using qconn buffer. Switch to use device instead of
file in the advanced mat settings. You need latest qconn for that.
Also 2G+ of data would be not that usefull in IDE anyway. Try to limit
data capture using mat options or programmatically by enabling/disabling
tracing from the code (I believe I sent you an API).
version of qconn and librcheck.so that works with this IDE.
> http://community.qnx.com/sf/go/post35863
Is the latest qconn available for 6.3.2?
With big memory leaks, it is easy to detect without having the rmat file grow too big.  I am looking into small leaks
now.  These leaks occur over a really long period of time.  Since I cannot tell when the leak will occur, I have to
capture continuous traces.  I have already tried disabling all unnecessary mat options, but I need a complete backtrace
so the file grows quite quickly.  I will switch to device and try again after I get the latest qconn.  Please let me
know where I can get one that runs on 6.3.2.
Hi, Rex,
I just posted the latest IDE 4.7 on our F27 download site
http://community.qnx.com/sf/frs/do/listReleases/projects.ide/frs.ide_4_7
It contains qconn patch to 6.3.2. If you can run this version of IDE
with your 6.3.2 Momentics, you can select from "Help -> Software Updates
-> qconn updates". IDE will handle updating your 6.3.2 qconn to the
latest version. You can transfer the qconn binary from your $QNX_TARGET
to your remote target.
Let me know if you can't run IDE 4.7. I can extract the qconn patch from
it and post it separately. But you have to install it by yourself.
- Andy
> http://community.qnx.com/sf/go/post35936
Thanks Andy.  I will give that a try.
You don't need IDE 4.7 for that. I think qconn that posted on foundry is
sufficient. IDE 4.7 has new UI for MAT tools and has not been tested yet.
> http://community.qnx.com/sf/go/post35944
I am still downloading IDE 4.7 which has the new qconn.  It is taking a while.  If you have a direct link to the new
qconn that works on 6.3.2, please let me know where it is.  I tried searching for it, but I could not find it.  I will
try IDE 4.6 with the new qconn first, once I have it.
Get the 6.3.2 qconn patch from here
http://community.qnx.com/sf/frs/do/viewRelease/projects.ide/frs.ide_4_7.ide_4_7_20090805
Download the "patch-632-1437-qconn-460.tar". You need to manually
extract the binaries from it.
> http://community.qnx.com/sf/go/post35956
Awesome.  I have it now and will try it.  Thank you.
Good. I have moved the two patches to its formal download area
http://community.qnx.com/sf/frs/do/listReleases/projects.ide/frs.binary_patches_for_ide
> http://community.qnx.com/sf/go/post35958
I tried the streaming device option to overcome the file size limitation but it does not seem to work.  I use IDE 4.6.0
I20090510 with the updated Qconn you posted. Here is what happens once I click on "get snapshots" and then export bin
events:
-The exported csv data is empty.
-The gauge at the bottom right of the IDE "Dump Snapshot" never seems to finish (it's been 45min and it is still going)
-The IDE seems to have lost connection with the machine because the target name in the Target File System Navigator
window has a red dot.
Note: I launched the project via the run Configuration window with the following parameters:
Memory Errors: Disabled
Memory Tacing: Disabled
Memory Snapshots: Enabled:
   - Perform Snashopt every : 100H
   - bins Counters: Default
Adcanced Settings:
  - Runtime Library: librcheck.so
  - Use streaming device: /dev/rcheck/traces.rmat
  - Create control thread: Enabled
  - Show Debug output on console: Enabled
Are you running it in debug mode or in run mode? Can you just try memory
leak example shipped with IDE with your settings on your target to see
it if works?
0 I20090510 with the updated Qconn you posted. Here is what happens once I click on "get snapshots" and then export bin
events:
going)
> Adcanced Settings:
> http://community.qnx.com/sf/go/post36391
Yes I'm running in run mode; I stated that in my original post, see below:
> > Note: I launched the project via the run Configuration window with ...
> it if works?
When I switch my setting from "Use streaming device" to "Use regular file" it works perfectly; expect that the rmat
file's size max out at 2G.
I guess something is not working... You can also try to use pipe -
create a pipe file on target and use its name instead of regular file.
Unfortunately you cannot use  control thread in this mode because it
would create dead locks, but if you can call for memory leaks dump using
API from the program it should work.
>> it if works?
> http://community.qnx.com/sf/go/post36536
