Re: /sbin/tinit won't start some programs
08/03/2009 5:32 PM
post35151
Weird...
In the ttys file I posted, I found out that the Momentics text editor doesn't add a line termination unless you CR to
the next line! That is, if your file is like
a
b
c|
with the vertical line representing the cursor, you'll find a newline between a and b, but not between b and c. You
have to do this:
a
b
c
I've never seen this before. In vi, for example, the cursor sits on the last line, not below it.
Anyway, tinit was barfing on the last line, not starting the process up.
-Jeff
