Forum Topic - SIGSEGV using mudflap applications: (6 Items)
When attempting to debug an application which is instrumented using mudflap (e.g. -fmudflap during compile, with -
lmudflap during link), it seg faults in a basic printf() with the following stack dump:
Thread [1] (Suspended: Signal 'SIGSEGV' received. Description: Segmentation fault.)
	19 _band_get_aligned()  0xfe328a0c
	18 _band_get()  0xfe328b30
	17 __malloc_lock()  0xfe32bd20
	16 __malloc()  0xfe32c23c
	15 malloc()  0xfe32b5a8
	14 backtrace_symbols() \home\builder\hudson\gcc-trunk\svn\libmudflap\mf-runtime.c:1990 0xfe388e68
	13 __mf_backtrace() \home\builder\hudson\gcc-trunk\svn\libmudflap\mf-runtime.c:2102 0xfe38903c
	12 __mfu_register() \home\builder\hudson\gcc-trunk\svn\libmudflap\mf-runtime.c:1074 0xfe38a0a8
	11 __mf_register() \home\builder\hudson\gcc-trunk\svn\libmudflap\mf-runtime.c:1174 0xfe38a1e8
	10 malloc() \home\builder\hudson\gcc-trunk\svn\libmudflap\mf-hooks1.c:126 0xfe38bacc
	9 _Fbuf()  0xfe356c64
	8 _Fwprep()  0xfe357404
	7 fwrite()  0xfe354c2c
	6 _Fprout()  0xfe356ed4
	5 _Printf()  0xfe35a63c
	4 vprintf()  0xfe35648c
	3 __mfwrap_printf() \home\builder\hudson\gcc-trunk\svn\libmudflap\mf-hooks2.c:1019 0xfe392444
	2 usage() c:\code\keystone\src\embed\ttdk\Util\devices\src\device.c:293 0x480423d8
	1 main() c:\code\keystone\src\embed\ttdk\Util\devices\src\device.c:1015 0x4804bba8
But when running the applicaiton directly from the console with the same environment settings, it runs just fine.
I've tried using the IDE tool for displaying the mudflap output, as well as just adding the MUDFLAP_OPTIONS environment
variable.
Anyone else seen this?
Bob
Re: SIGSEGV using mudflap applications
Is your app multithreaded? What happens if you press continue after
SIGSEGV is received?
environment variable.
> Thanks,
> Bob
> http://community.qnx.com/sf/go/post34237
The app is not multi-threaded and pressing continue results in termination of the program (simillar to what would happen
 if you had a real SIGSEGV problem).
Seems odd to me to have the SIGSEGV so low in the internals when running in the debugger, but not when running from the
console.
Bob
Btw. Do you use IDE to debug? If so please uncheck "Use unique name" in
Upload tab of launch configuration. It was a bug in 6.4.0 mudflap
library that makes it crash.
happen if you had a real SIGSEGV problem).
the console.
> Thanks,
> Bob
> http://community.qnx.com/sf/go/post34262
Yes indeed I was using the debugger, and that did the trick!  BTW I'm using 6.4.1, so this must have carried forward
into 6.4.1.
Thanks for the help -- much appreciated.
Bob
I have the same problem, unique name is uncheck though ;-(  The program only crashed when I use mudflap. it crashed
before main()..  Could be cause by the C++ constructor of a global variable.
	28 _band_get_aligned()  0xb03273f6
	27 _band_get()  0xb032745c
	26 __malloc_lock()  0xb032a10f
	25 __malloc()  0xb032a604
	24 malloc()  0xb0329abd
	23 backtrace_symbols() /home/builder/hudson/gcc-trunk/svn/libmudflap/mf-runtime.c:1990 0xb86c5225
	22 __mf_backtrace() /home/builder/hudson/gcc-trunk/svn/libmudflap/mf-runtime.c:2102 0xb86c533c
	21 __mf_violation() /home/builder/hudson/gcc-trunk/svn/libmudflap/mf-runtime.c:2189 0xb86c5ab7
	20 __mfu_check() /home/builder/hudson/gcc-trunk/svn/libmudflap/mf-runtime.c:1044 0xb86c6b3f
	19 __mf_check() /home/builder/hudson/gcc-trunk/svn/libmudflap/mf-runtime.c:823 0xb86c6cdb
	18 std::string::_Myptr() /opt/qnx641/target/qnx6/usr/include/cpp/xstring:1683 0x0807d161
	17 std::string::_Eos() /opt/qnx641/target/qnx6/usr/include/cpp/xstring:1628 0x0808063c
	16 std::string::_Tidy() /opt/qnx641/target/qnx6/usr/include/cpp/xstring:1674 0x08080993
	15 basic_string() /opt/qnx641/target/qnx6/usr/include/cpp/xstring:453 0x080820e7
	14 <symbol is not available> 0xb85b3cf2
	13 <symbol is not available> 0xb8657fb4
	12 <symbol is not available> 0xb86091c5
	11 <symbol is not available> 0xb8603e1b
	10 <symbol is not available> 0xb86558ac
	9 <symbol is not available> 0xb865043c
	8 <symbol is not available> 0xb84bf770
	7 <symbol is not available> 0x08046c34
	6 <symbol is not available> 0xb86048ee
	5 <symbol is not available> 0xb0377108
	4 <symbol is not available> 0x0830c500
	3 <symbol is not available> 0x08046d28
	2 <symbol is not available> 0xb84bf77a
	1 init()  0xb033fafa
