Forum Topic - Touchscreen on QNX6.4.1: (13 Items)
Hi!Everyone,I try to run egalax touchscreen on QNX6.4.1.The file of touchscreen's driver about installed.
(Touchscreen driver Readme file)
Revision	: 1.01.5608
OS	: QNX Neutrino RTOS v6.3
Release Date	: 08-08-2006
File list:
TouchKit			- Utility
devi-eGalax		- RS232 Touch Screen Driver
input.localhost.txt		- Input Data
calib.localhost.txt		- Calibration Data
Notes:
     This Driver only support RS232.
1.  Copy "Touchkit" and "devi-eGalax" two files  to '/usr/photon/bin ' directory.
2.  Change it's Permissions and make it Executable.
3.  Open or Create "input.localhost" under '/etc/system/trap' and copy two lines to the file :
    		kbd fd -d/dev/kbd ps2 mousedev
    		devi-eGalax egalax fd -d/dev/ser1 abs
    Notes:
    	 "ser1" it means only support com1.You can change it to "ser2" to support com2.
4.  Open or Create "calib.localhost" under '/etc/system/trap' and copy the line to the file :
    		0x0:1023x767:0 2047 0 2047 0
When I do so that.I run
(1)#usb -vv
Device Address             : 1
Upstream Host Controller   : 1
Upstream Device Address    : 0
Upstream Port              : 0
Upstream Port Speed        : Full
Vendor                     : 0x0eef (eGalax Inc.)
Product                    : 0x0001 (USB TouchController)
Device Release             : r1.00
USB Spec Release           : v1.10
Serial Number              : N/A
Class                      : 0x00 (Independent per interface)
Max PacketSize0            : 64
Languages                  : 0x0409 (English)
Configurations             : 1
  Configuration            : 1 (eGalax Inc.)
    Attributes             : 0xa0 (Bus-powered, Remote-wakeup)
    Max Power              : 100 mA
    Interfaces             : 1
      Interface            : 0 / 0
        Class              : 0x03 (HID)
        Subclass           : 0x00
        Protocol           : 0x00
(2)#io-hid -degalax
(3)#devi-eGalax -vvvvvvvv egalax fd -d/dev/ser1 -b
Looking up egalax in module table
Allocated static module egalax at 8059660
Looking up fd in module table
Allocated static module fd at 80597a0
fd_parm: d
optarg: /dev/ser1
Looking up abs in module table
Allocated static module abs at 80599a0
Calibration filename: /etc/system/trap/calib.localhost
Adding filter module: abs
Resetting module fd
Opened a serial device
Resetting module egalax
Resetting module abs
Attempting to open calibration file: /etc/system/trap/calib.localhost
Did not find calib info for [639x479]
Calibration parameters
sxl : 0 sxh : 639
syl : 0 syh : 479
rxl : 0 rxh : 0
ryl : 0 ryh : 0
interrogate bus, returning abs
Attempting to determine graphics region dimensions
Found graphics region owned by local hardware
Graphics region dimensions are 0:0 799:599
Issuing devctrl to abs
Found calib info for [799x599]
sxl : 0 sxh : 799
syl : 0 syh : 599
rxl : 0 rxh : 799
ryl : 0 ryh : 799
Touch screen device driver received data from Photon server.
(4)#./Touchkit[Calibrate a touchscreen]
result:touchscreen nothing to do
my questions:
(1)The touchscreen and driver is matched?
(2)Touchscreen's driver install process is  correct?
(3)QNX6.4.1 touchscreen driver is supportted?
Thank you very much!
Re: Touchscreen on QNX6.4.1
Hi Hu,
So you know this question is best suited for the BSP/Drivers Forum, also we ask that you don't cross post between forums
Can you please post the output from 'hidview -R'
Thanks and best regards,
Erick
> File list:
> TouchKit			- Utility
> Notes:
> directory.
> lines to the file :
>     Notes:
>  com2.
> line to the file :
> (1)#usb -vv
> Device Address             : 1
> Upstream Port              : 0
> Serial Number              : N/A
> Configurations             : 1
>     Max Power              : 100 mA
>     Interfaces             : 1
>       Interface            : 0 / 0
>         Class              : 0x03 (HID)
>         Subclass           : 0x00
>         Protocol           : 0x00
> (2)#io-hid -degalax
> fd_parm: d
> optarg: /dev/ser1
> Resetting module fd
> sxl : 0 sxh : 639
> syl : 0 syh : 479
> rxl : 0 rxh : 0
> ryl : 0 ryh : 0
> sxl : 0 sxh : 799
> syl : 0 syh : 599
> rxl : 0 rxh : 799
> ryl : 0 ryh : 799
> Touch screen device driver received data...
I`m very sorry to post my question in two forums.
I run "hidview -R".
Attachment: Text hidview_log.7z 1.03 KB
Hi Hu,
Its ok, sometimes people are not aware.
I have the same controller here, Egalax makes some strange controllers sometimes as the HID parser tends to break as
they have two report descriptors for what would appear to be two devices to our parser comming from the single
controller.  As a result the parsing breaks (Windows does too, which is why they have a Windows specific driver).  I am
hoping to have a fixed driver for this, are you in a time critical situation? as there is a quick hack that should get
it going for you if you are interested.
Best regards,
Erick
> I run "hidview -R".
I'm sorry to ask a question again!
The touch screen of QNX car is Egalax.But the driver is devi-microtouch.
This is OK?
Hi Hu,
Sorry for the delay, I am very busy :(
The QNX car demo was using the Egalax screens at one point, however we found that they were not very responsive and
difficult to use.  So we moved to a capacitive based screen by Microtouch (at least that was the plan at one time).
With regards to your Egalax screen, I am still in the process of trying to get time to fix this in house.  Once I have
done so I can post an experimental driver for you.
Best regards,
Erick
> This is OK?
Hi Hu,
Try the attached driver, it is experimental _only_ at this time, and is not to be shipped with any products.
io-hid -dusb igndev=0x0eef:0x0001 -degalax hid=2
Best regards,
Erick
> Hi Hu,
> that they were not very responsive and difficult to use.  So we moved to a
> .  With regards to your Egalax screen, I am still in the process of trying to
> get time to fix this in house.  Once I have done so I can post an experimental
>  driver for you.
> Best regards,
> Erick
> > This is OK?
Attachment: Text devh-egalax.so 38.22 KB
Hi Eric,
I have the same problem.
Here is what I have found out together with the german qnx support:
The device is seen by usb -vvv and it is the same revision numbers as reported here.
I tried both the egalax shipped with 6.4.1 and your experimental one. Both not working.
I didn't use a trap file. There is a PS2 mouse and keyboard and a USB mouse connected to the target. (All of them
autodetected).
hidview -R is listing all devices including the egalax.
hidview -a is showing data when I touch the screen and when I move around, but it shows no entry when releasing my
finger from the screen.
Data is 6 byte where the last byte is allways 0. It seems that all other 5 bytes are related to position information as
the all vary when I move around on the screen leaving my finger on it.
instead of your provided line I used the mount command, because io-hid was already running:
mount -T io-hid devh-egalax.so
greetings,
stefan
I do facing the same issue. I tried both RS232 and USB interface.
Is there any update on this issue? Is that egalax touch working?
I re-wrote the driver for 6.5.0 which ironed out the issues that we were seeing with the driver and the new driver (USB)
 works much better now, you can request to get a PSP of it if you happen to have a priority support plan.  The other
option is to request the source code to the 6.5.0 or the latest 6.4.1 version, as the code has already been merged in
both branches.
Best regards,
Erick
Hi Erick,
Thank you for your reply.
We have developed our product with QNX6.4.1 on X86 platform target (Advantech PCM9361 SBC board) and our support plan
has since expired. Currently the project is on-hold but we are planning to restart activity in a few months. In the
meantime, I am working on an internal demo. Could you please provide the Egalax USB touch screen driver binary and
installation instruction for us to use in our demo? We are not asking for the Source code.
Mani
Hi Erick,
FYKI, I am using EETI projected capacitive touch screen.
Mani
Doh, thats no good, the driver was for the resistive screens only, I have not had one of the projected screens in house
yet.
Sorry :(
Erick.
> Hi Erick,
> Thanks,
> Mani
