Forum Topic - ApOptions in PhAB Application: (7 Items)
According to the documentation, I should be able to add command line options to the ApOptions array. I have:
/* Application Options string */
const char ApOptions[] =
	AB_OPTIONS "vo:mVP:C:"; /* Add your options in the "" */
Yet when I invoke my app with arguments "-P path", ApInitialize() terminates with the error "Unrecognized option: '-P'"
Any idea if there is a workaround for this?
Re: ApOptions in PhAB Application
I may be beyond my understanding, but it looks to me as though there is an ApOptions variable in libAp.so, so there may
be a linking issue where ApInitialize() sees the copy in the library, not the ApOptions in my program.
This works for me.
Are you sure that it is the ApInitialize() that reports this problem?
Can you make a small sample app that shows this problem?
Misha Nefedov wrote:
> This works for me.
Yes, I traced it in the debugger.
I'll try.
OK, no, my small test program does not exhibit the same symptom. Instead it will not complain even if I give it invalid
options. In the attached, I have specified:
  AB_OPTIONS ""; /* Add your options in the "" */
and in mysetup() I just dump the command line and the ApOptions array. The output of a run with bogus options gives me:
mysetup(4, 'ApOptions_gnort124154077390614', '-P', 'path', '-X'
ApOptions[] = "s:"
Attachment: Compressed file ApOptions.zip 41.32 KB
The debugger fooled me. It terminated while stepping over ApInitialize(), but in fact it went on to execute the
following function call. I guess ApInitialize() never complains about arguments it doesn't recognize.
You are right. ApInitialize() doesn't complain about errors.
