Forum Topic - Code Coverage for c++ project: (8 Items)
I created c++ project in the Momentics IDE 4.0.1.
I have run that project. When i checked for the code coverage.
I found coverage to be the 90% only.
Please find the attached project folder on which i tried.
The coverage data is as follows:
main : 80%
fun1: 75%
Target_based.cc: 88.9%
Here i am running all the lines of code. but still it is showing lesser coverage information
Can any one, give the reason for this?
The same type of  C project  is working fine.Its showing 100% coverage information.
Vijay.
Attachment: Compressed file MyWorkspaceTarget.zip 134.51 KB
Re: Code Coverage for c++ project
Thanks for attaching your project. We will investigate.
vijay kumar wrote:
> main : 80%
> fun1: 75%
> Thanks,
> Vijay.
> http://community.qnx.com/sf/go/post28591
Please look at attachment. I used 4.6 IDE, but I think that the same result you will get usiing 4.5 wiith gcc 4.2.
Attachment: Image Target_based.png 70.3 KB
Alex,
I am working on Momentics IDE 4.0.1 on QNX System.
I found the problem, It  is with the Launch configuration of the Debug.
When i try to debug the project, its giving the Error while Connecting to Target system.
Its becoming a failure while connecting to the target sytem.
So i am not getting the Code coverage of target system.
I don't know how to connect the target system.
Please let me know how to do this?
Vijay.
Last time we talked about it you were trying to run it on Windows. Do you have a target system?
vijay kumar wrote:
> Alex,
> Thanks,
> Vijay.
> http://community.qnx.com/sf/go/post28721
I have the Target system(QNX 6.4.0).
Now i tried with the same attached project on Momentics IDE 4.5.0 . I got 100% coverage.
When i tried the same project on Momentics on 4.0.1, Its giving as 90% covearage on QNX Host(6.3.2).
But the same project when I used the "cout" instead of "printf's".
by enabling the "iostream" and "cstdlib" header files instead of "stdio.h"
and "stdlib.h" in Momentics 4.5.0
I am not getting the 100% coverage information.
Can you please give the reason for this?
Thaks,
Vijay.
If you use classes in your C++ program (which is very natural, by the way:-), for gcc 3.x and older (gcc++ ABI)  you
newer get 100% block(branch) coverage because of gcc++ implementation  specific .  Below is a fragment extracted from <
http://www.google.ca/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&q=gcc+c%2B%2B+abi+constructor+two+destructors&btnG=Search&meta= >, which should explain you why it happens.
G++ emits two copies of constructors and destructors.
    In general there are three types of constructors (and destructors).
       1. The complete object constructor/destructor.
       2. The base object constructor/destructor.
       3. The allocating constructor/deallocating destructor.
    The first two are different, when virtual base classes are involved.
Line coverage should be free of this specific.
Thanks a lot, for this sharing this information.
Vijay
