Forum Topic - What file stores the project type ? : (5 Items)
Customer creates a static library project, and checks 'the files' into subversion.
Evidently, they don't check in enough, because when they check it out, it defaults back to a C application.
What do they need to check in/out to 'remember' the project type ?
Is it just the x86/a subdirs, or is there a metafile that 'knows' this stuff ?
Thanks !
Dave
Re: What file stores the project type ?
Depends what project type it is. Look like this is Qnx Project? Most of the stuff stored in makefiles (Makefile and
common.mk) in this case.
> Thanks !
> Dave
> http://community.qnx.com/sf/go/post28405
RE: What file stores the project type ?
Thanks Elena,
Yes, I believe that this is a QNX project - they swear that checking it in then out loses the library type and reverts
to application... Most odd.
Dave
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: Thu 30/04/2009 6:14 AM
To: momentics-community
Subject: Re: What file stores the project type ?
> Thanks !
> Dave
http://community.qnx.com/sf/go/post28437
Attachment: Text winmail.dat 4.06 KB
Maybe .cproject gets corrupted.  Happens to me all the time.
> From: Dave Bott [mailto:community-noreply@qnx.com]
> Sent: April-30-09 11:17 AM
> Subject: RE: What file stores the project type ?
> Thanks Elena,
> in then out loses the library type and reverts to application... Most
> odd.
> Dave
> the stuff stored in makefiles (Makefile and common.mk) in this case.
> into subversion.
> this stuff ?
> > Thanks !
> > Dave
> http://community.qnx.com/sf/go/post28460
There is another flag in Main page called "share project" if you enable that it will also
store some other settings such as active configurations in .settings/ directory in project. They can try that.
Dave Bott wrote:
> Thanks Elena,
> in then out loses the library type and reverts to application... Most odd.
> Dave
> into subversion.
> this stuff ?
>  > Thanks !
>  > Dave
>  > _______________________________________________
