Forum Topic - PtTree instability: (5 Items)
PtTree instability
I have a PtTree with a PtDivider to use two columns. I am currently trying to use no images. In a separate dialog, I
have PtText widgets to edit the names of some of the tree items. Whenever the PtText widgets are updated
(Pt_CB_MODIFY_NOTIFY), I call
   PtTreeChangeItem(tree, item, newname, NULL);
to update the tree text. Before long (after 4 or 5 updates) I get a SIGSEGV from within PtTreeChangeItem():
  32 _list_release()  0xb0327324
  31 __prelocked_free()  0xb0328b0e
  30 __free()  0xb0328c79
  29 free()  0xb0325b1d
  28 __realloc()  0xb0328879
  27 realloc()  0xb0325bf4
  26 PtGenListItemRealloc()  0xb826f0d1
  25 PtGenTreeItemRealloc()  0xb8277f1a
  24 tree_setstring()  0xb82d2058
  23 PtTreeChangeItem()  0xb82d2101
The tree items are created with:
  TreeItem = PtTreeAllocItem(ABW_Graphs_Tab, temp_buf, -1, -1);
The documentation for PtTreeChangeItem is vague as to the implications of passing in a NULL for the attributes argument.
 It says:
  Set to NULL to display no images, and use the widget-defined font and
  colors. The Pt_TREE_ITEM_HAS_ATTRS flag bit is still set for the item.
What are the implications of having Pt_TREE_ITEM_HAS_ATTRS set, particularly if no attrs have been supplied? Is it
possible that the library is attempting to dereference the attribute pointer or free it?
Re: PtTree instability
Based on your snippet and the backtrace -- your are trying to free an item that is already freed. The PtTreeChangeItem()
 may return a new item that you have to maintain. Your code should like this:
new_item = PtTreeChangeItem(tree, item, newname, NULL);
if( new_item != null ) {
item = new_item;
} else {
// TODO: Handle this error!
-Misha.
Ah, that would do it!
PtTreeChangeItem() may return a new item that you have to maintain. Your code should like this:
> item = new_item;
> } else {
> Regards,
> -Misha.
> http://community.qnx.com/sf/go/post27780
Yes, thanks. That resolved it. That little fact rather escaped me in the documentation. I'm glad I managed to get enough
 context into the post for you to see the problem. I'm sure looking forward to seeing the Photon source code!
Thanks for posting Norton. I'll see that the docs get updated accordingly.
