Forum Topic - Virtual Serial port pronblem: (12 Items)
I'm trying to use a USB-UART chipset for which I have invoked the devc-serusb driver. I'm able to get two nodes /dev/
serusb1 & /dev/serusb2. The chipset vendor is FTDI.
I have connected /dev/serusb1 & /dev/ser1 through this chipset and cable. I write a sample data into /dev/serusb1 and
read it from /dev/ser1 but I don't get any data. When I checked with cat /dev/serusb1, I could find the data in it still
My question is what could be the reason behind the written data not getting transmitted out of /dev/serusb1, although
the APIs return success?
I have treated the virtual serial port the same way as the conventional serial port. Is there anything specific that
needs to be taken care for virtual serial ports?
Lakshminarayanan.R
PS:
1) I tried the same chipset in windows with the driver provided by the vendor it works!
2) And in QNX host, when I connect /dev/ser1 to /dev/ser2 through cables, if some data is written in /dev/ser1 it is
available in /dev/ser2. If I do a cat in /dev/ser1 - no data is there and cat /dev/ser2 gives the output data!
Re: Virtual Serial port pronblem
Not sure what is wrong , but you could check this things:
/root# uname -a
QNX EA869dfc 6.4.0 2008/10/21-11:10:39EDT x86pc x86
/root# usb
USB 0 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 1 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 2 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 3 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
Device Address             : 1
Vendor                     : 0x067b (Prolific Technology Inc.)
Product                    : 0x2303 (USB-Serial Controller)
Class                      : 0x00 (Independent per interface)
USB 4 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
/root# pidin -pdevc-serusb arg
     pid Arguments
149442622 devc-serusb -d vid=0x067b,did=0x2303,busno=0x03,devno=0x01
/root# pidin -pdevc-ser8250 arg
     pid Arguments
   94222 devc-ser8250 -u1 3f8,4 -u2 2f8,3
/root#use devc-serusb
/root# ls /dev/ser*
/dev/ser1        /dev/ser2        /dev/serusb1
/root# stty -a </dev/ser1
Type:  serial
Opens: 1
+hupcl +cread -clocal -isig -icanon -iexten -echo -echoe -echok -echoke -echonl -echoctl -noflsh -ignbrk -brkint -ignpar
 -parmrk -istrip
-inlcr -igncr -icrnl +imaxbel -opost +onlcr
-isflow -osflow +ihflow +ohflow
 intr=^C  quit=^\ erase=^?  kill=^U   eof=^D   eol=^-  eol2=^- swtch=^-
start=^Q  stop=^S  susp=^Z dsusp=^- reprint=^- discard=^- werase=^- lnext=^V
  min=01  time=00   fwd=^- login=^-   pr1=^[   pr2=5B   pr3=^-   pr4=^-
  sf1=^-   sf2=^-   sf3=^-   sf4=^-  left=44 right=43    up=41  down=42
  ins=40   del=50   rub=^-   can=^-  home=48   end=59
par=none bits=8 stopb=1 baud=57600 rows=0,0
/root# stty -a </dev/serusb1
Type:  serial
Opens: 1
 -parmrk -istrip
reading/writing data from/to /dev/ser1-/dev/usbser1 works for me.
Hope this helps.
Jeevan
> driver. I'm able to get two nodes /dev/serusb1 & /dev/serusb2. The chipset
> vendor is FTDI.
> write a sample data into /dev/serusb1 and read it from /dev/ser1 but I don't
> it still.
> transmitted out of /dev/serusb1, although the APIs return success?
>  port. Is there anything specific that needs to be taken care for virtual
> serial ports?
> Thanks,
> Lakshminarayanan.R
> PS:
> it works!
> some data is written in /dev/ser1 it is available in /dev/ser2. If I do a cat
Re: Virtual Serial port problem
Please find my console statements.
uname:
QNX QNX_Target 6.4.0 2008/10/21-11:10:24EDT x86pc x86
usb:
USB 0 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
Device Address             : 1
Vendor                     : 0x0403 (FTDI)
Product                    : 0x6010 (USB <-> Serial Cable)
USB 4 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
pidin -pdevc-serusb arg:
     pid Arguments
  626726 devc-serusb -d vid=0x0403,did=0x6010,busno=0x02,devno=0x01,module=ftdi
pidin -pdevc-ser8250:
     pid Arguments
  106513 devc-ser8250 -u1 3f8,4 -u2 2f8,3
ls /dev/ser*:
/dev/ser1
/dev/ser2
/dev/serusb1
/dev/serusb2
stty -a </dev/ser1:
Type:  serial
Opens: 1
-echoctl -noflsh -ignbrk -brkint -ignpar -parmrk -istrip -inlcr -igncr -icrnl
stty -a </dev/serusb1:
Type:  serial
Opens: 1
If I load "devc-serusb" without specifying module=ftdi, virtual serial port is not created in the system.
If I query devc-serusb for supported hardware modules, I can see ftdi in it! My suspect is whether this driver can
support all ftdi chipsets???
Should the virtual serial port be treated any different than regular serial ports??
Update!
I learn from this file /etc/system/enum/devices/usb/char that it supports FTDI chipset with device ID 6001. But the FTDI
 chipset I'm using is with device ID 6010. So I guess that model isn't supported yet.
Is it possible to add a device entry with device ID of this model in that configuration file so that it can be verified
if the existing driver works?
RE: Virtual Serial port problem
Hi:
	"use devc-serusb" tells you the options that are supported by
the devc-serusb driver.  I believe that two of the options are "vid" and
"did" which let you specify the vendor ID and device ID to use (you'll
probably have to specify both.  You may also have to specify the busno /
devno options).
	R.
From: Lakshminarayanan R [mailto:community-noreply@qnx.com]
Sent: Wednesday, April 22, 2009 7:26 AM
To: momentics-community
Subject: Re: Virtual Serial port problem
Update!
supports FTDI chipset with device ID 6001. But the FTDI chipset I'm
that configuration file so that it can be verified if the existing
driver works?
http://community.qnx.com/sf/go/post27706
Re: RE: Virtual Serial port problem
Robert, kindly refer to the earlier posts in this thread. I have listed down the options which I have tried and it
includes vid, did, busno, devno.
RE: RE: Virtual Serial port problem
Missed that.  That's the problem with no history in the individual forum
posts :->>
In any case, I'm now confused.  Did the driver work with the options you
passed and you're now asking how to modify the enumerator configuration
files so that the driver can be started with those options
automatically?  I wouldn't expect the driver to support all FTDI chip
variants automatically.
 R.
Sent: Wednesday, April 22, 2009 8:35 AM
Subject: Re: RE: Virtual Serial port problem
down the options which I have tried and it includes vid, did, busno,
devno.
http://community.qnx.com/sf/go/post27713
Re: RE: RE: Virtual Serial port problem
The driver got loaded and I could see the /dev/serusb nodes after loading. And I don't see any errors in slog. But, when
 I write some data into that port it remains there itself.
cat sample > /dev/serusb1
cat /dev/serusb1 shows the contents of the sample file. This should be available on the other end of the connection.
Although the driver gets loaded and nodes are available, the communication is not succeeding. So, basically it is not
working. For this, I thought if I could change this configuration and allow it to mount automatically and see how it
works.
The driver which I'm using is FT2232D - USB to Dual UART - and the driver which is claimed to be supported by QNX is
FT8U232AM - USB to single UART.
Any idea if this existing driver will work for FT2232D chipset??
once you load the driver , how can I communicate with it in a C program. can I use the ftdilib or what else? hope
anybody can help me!! thanks
Once you load the driver check for /dev/serusb* entries. If you find one, you have rightly installed the driver and you
can communicate with it like the way you communicate with any other serial port.
Instead of /dev/ser* just use the appropriate /dev/serusb*.
Hope it helps!
i used to handle serial port with termios.h, my problem is that i need the serial.h lib to set the baudrate to a custom
one (512Kbaud) for this reason i need too call ioctl() with constant TIOSSSERIAL and a struct serial. i see that serial.
h doesn't exists. otherwise i wanted to use the ftdi lib to communicate with my ftdi chip. has anybody experience with
such a problem??
If not tried earlier, try using tcgetattr and tcsetattr to change the baud rate.
Hope it helps!
