Forum Topic - Change active build variant without going into the properties window: (5 Items)
I have a large number of applications and libraries that make up my system.  In Momentics, they are all individual
projects.  I am building for two architectures (ARM and X86).
Some applications depend on multiple libraries.  When I am switching between x86 and ARM debugging, I have go into the
properties box of each library and application and change the active variant from x86 to ARM, then clean and rebuild.
Is there a faster way to globally change the active build variant for multiple applications in the IDE?
I can't leave them both active due to build time issues on the larger applications.
- Mike
Re: Change active build variant without going into the properties window
Are you using managed project and qnx project?
If you using qnx project you can use Container project. It allow to group project and create build configuration for
example for x86 only for all projects. Then you initiate build from container project.
See docs for more info.
Yes, I am using a qnx project.
I have a container project, and I tried the build configuration.  It is close to what I was looking for.
However, I have two variants besides release and debug (unittest_g and unittest_r).
How do I add these to the selections in the build Configuration of the container.
It appears that while I can select which projects get build in the configuration, I still have to go to the container
project to build them each time.
What I was really hoping for was a way to override the C++ project properties globally so that I can right click on the
individual project I am working on and say build just for that project.  This would save me time as I may be switching
between projects as I debug, but I don't want to build all projects every time I make a change to one.
Thanks for the help.
- Mike
If you want to build each project you have to go to properties and switch configuration. (Or you leave them both). There
 is no easier way to switch build variant.
If you want to build set of project you can use container project.
the individual project I am working on and say build just for that project.  This would save me time as I may be
switching between projects as I debug, but I don't want to build all projects every time I make a change to one.
> - Mike
> http://community.qnx.com/sf/go/post25826
