Forum Topic - invoking phfont gives PfAttachServerDll() error: (11 Items)
I'm trying to invoke phfont, but when I issue the command I get this message
PfAttachServerDll(): Invalid argument
Why am I not able to invoke phfont and why is this message displayed?
Thanks in advance,
Lakshminarayanan.R
Re: invoking phfont gives PfAttachServerDll() error
1. What does sloginfo say?
2. Check that the LD_LIBRARY_PATH contains /lib/dll in it.
3. Do you have io-graphics running? If you do, it probably ran the phfont server already.
1) Ths sloginfo says this:
phfont: init...
phfont: initialized.
phfont: unable to set up resource manager /dev/phfont
2) LD_LIBRARY_PATH has /lib/dll as one of the paths.
3) I just tried ps and I don't find io-graphics running. Is there any other way to check that?
pidin
ls -l /dev/phfont*
1) pidin doesn't show entry for phfont
2) /dev/phfont, /dev/phfont32, /dev/phfont64
In one of the previous emails I referred to io-graphics running phfont(.so):
pidin -P io-graphics mem
will show the phfont.so in it, because the /dev/phfont* entries exist.
You are correct, I could find the DLL phfont.so loaded.
But, how can I reload it? Just giving phfont doesn't work!
I am not sure why you want to "reload" it.
Take a look at this doc that contains details about the font system configuration: http://www.qnx.com/developers/docs/6.
4.0/photon/prog_guide/embed.html#configuring_fonts
I have the system up and running and I have to set the anti-aliasing option for fonts now so that I could visualize it.
If you look at 6.3.2 there used to be an option in the shelf itself as font admin. But, my eyes couldn't catch one in 6.
4.0 for which I'm trying to do that from command line using phfont -A option.
In 6.4.0 the /usr/photon/font_repository/fontopts should have in it:
[io-font]
-A
It works, thanks!
Any thoughts on why fontadmin is not there in 6.4.0?
