Re: Initialising New Open type type fonts
02/25/2009 1:26 AM
post22878
Hey, first of all, thanks for your response!
But, I learnt from one of the QNX vendors that Open type fonts are supported. Appending more information onto it, when I
try to view sample of the font after depositing the .otf file in font_repository I get a message in the terminal "
Rendering DLL's not found for that type of fonts". So I guess there should be rendering DLL's for open type fonts as it
is available for ttf fonts.
Any other views on this?
And How do you install the fonts? I guess it is not sufficient if you just drop it in the repository. In earlier
versions, there used to be the mkfontdir command for absorbing it into the repository.
Lakshminarayanan
