Forum Topic - Failed to connect Qnx6.4 over vmware with phindow : (4 Items)
  I created a vitrual machine of Qnx Neutrino 6.4 with VMWare workstation, just because I can't start with QNX DVD for
some reason of my dell optiplex 755. But , I Can't connect to the Qnx 6.4 virtula image by phindows.
  I looked the QNX Momentics IDE Help, and follow the chapter of Qnx Momentics Phindows Connectivity to set up the qnx 6
.4.
  I had configed /etc/inetd.conf and added the line
     'phrelay stream tcp nowait root /usr/bin/phrelay phrelay -x',
  and edited the  /etc/services, added the line
     'phrelay 4868/tcp'
  But the phindows work not too.And the error message is
     'Unable to connect to remote host 192.168.56.128.The attempt to connect was rejected'
   How can I do something to repaire this question.
  Thank you!
RE: Failed to connect Qnx6.4 over vmware with phindow
1) Please make sure inetd is running.
2) If you make inetd.conf changes while inetd is running, you need to
send it a sighup to make it process the changes: slay -shup inetd
From: liu liming [mailto:community-noreply@qnx.com]
Sent: Friday, February 20, 2009 4:42 AM
To: momentics-community
Subject: Failed to connect Qnx6.4 over vmware with phindow
workstation, just because I can't start with QNX DVD for some reason of
by phindows.
Momentics Phindows Connectivity to set up the qnx 6.4.
     'phrelay 4868/tcp'
  Thank you!
http://community.qnx.com/sf/go/post22592
Re: RE: Failed to connect Qnx6.4 over vmware with phindow
Well, unfortunately I see a similar problem. I can telnet and connect the IDE to it but Phindows fails with the short
Message: "Unable to connect to remote host hostname-of-qnx"
RE: RE: Failed to connect Qnx6.4 over vmware with phindow
If telnet works, that means IP is ok.  The problem must be that phrelay is not enabled in /etc/inetd.conf. I think by
default it`s commented out.
> From: one infinite [mailto:community-noreply@qnx.com]
> Sent: March-12-09 11:24 AM
> Subject: Re: RE: Failed to connect Qnx6.4 over vmware with phindow
> the IDE to it but Phindows fails with the short Message: "Unable to
> http://community.qnx.com/sf/go/post24240
