Forum Topic - Doc Error: PtTree: (2 Items)
Doc Error: PtTree
The pages:
http://www.qnx.com/developers/docs/6.3.2/photon/widget_ref/pttree.html
http://www.qnx.com/developers/docs/6.4.0/photon/widget_ref/pttree.html
both contain an error in the example code for using images in columns. The code sets up arguments for
Pt_ARG_TREE_COLUMN_ATTR, but the PtSetResource() call specifies Pt_ARG_LIST_COLUMN_ATTR.
To be clear, this section contains two calls to PtSetResource. The first correctly sets Pt_ARG_LIST_COLUMN_ATTR. The
second should set Pt_ARG_TREE_COLUMN_ATTR, but instead sets Pt_ARG_LIST_COLUMN_ATTR again.
RE: Doc Error: PtTree
I've created a doc PR for this. Thanks for pointing out the error.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
